It is currently Sun Aug 10, 2025 12:30 am
PostPosted: Mon Aug 25, 2014 6:38 pm
Hi all, what is the difference between wet and dry rear trailing arms?
Edit: I want to fit coil springs and hilos, is it just the stub axle or is there something else?
Cheers Richard.
PostPosted: Mon Aug 25, 2014 6:45 pm
Rears?? Different length of the pivot arm.... to install a a wet arm with a dry cone will require a massive hilo...
Cheers, Ian
PostPosted: Mon Aug 25, 2014 7:16 pm
Cheers, Ian
So is the knuckle point further back?
PostPosted: Mon Aug 25, 2014 10:43 pm
The cup for the knuckle is farther forward on the hydro arms. The tabs for the brake lines are on the bottom rather than the top, stub axle has a different spigot for mounting the helper spring rather than a shock, and the hydro arm also has a bump stop mount, which the dry don't (i think)
PostPosted: Tue Aug 26, 2014 6:59 am
Another thing to keep in mind is if you use dry arms in a wet subframe (like I've done :roll: ) you end up with no bump stop at all, so if I want to go anywhere with the kids in the back I have to wind the hilo's up an inch. till I fix it that is
