https://ausmini.com/forums/
Wet versus Dry swing arms
https://ausmini.com/forums/viewtopic.php?f=2&t=87003
Author:  bluewhitecoopers1968 [ Mon Aug 25, 2014 6:38 pm ]
Post subject:  Wet versus Dry swing arms
Hi all, what is the difference between wet and dry rear trailing arms?
Edit: I want to fit coil springs and hilos, is it just the stub axle or is there something else?
Cheers Richard.
Author:  1071 S [ Mon Aug 25, 2014 6:45 pm ]
Post subject:  Re: Wet versus Dry swing arms
Rears?? Different length of the pivot arm.... to install a a wet arm with a dry cone will require a massive hilo...
Cheers, Ian
Author:  bluewhitecoopers1968 [ Mon Aug 25, 2014 7:16 pm ]
Cheers, Ian
So is the knuckle point further back?
Author:  JimL [ Mon Aug 25, 2014 10:43 pm ]
The cup for the knuckle is farther forward on the hydro arms. The tabs for the brake lines are on the bottom rather than the top, stub axle has a different spigot for mounting the helper spring rather than a shock, and the hydro arm also has a bump stop mount, which the dry don't (i think)
Author:  1275greg [ Tue Aug 26, 2014 6:59 am ]
Another thing to keep in mind is if you use dry arms in a wet subframe (like I've done :roll: ) you end up with no bump stop at all, so if I want to go anywhere with the kids in the back I have to wind the hilo's up an inch. till I fix it that is
