It is currently Thu Aug 14, 2025 12:49 am
 Post subject: Air Conditioning Options
PostPosted: Sun Aug 24, 2014 12:11 pm
So with summer approaching I want to fit an air con system to my clubman estate. I have heard varying reports on rover air con set ups, some say they are a waste of time and others say they are pretty good.
Has anyone fitted an aftermarket custom air con system or is the rover air con set up the easiest option?
Will a rover system work on a bmw twinky motor?
1965 Riley Elf
1974 Ex Army Moke
1997 Rover Cooper
2002 JCW Cooper
2003 JCW Cooper S
PostPosted: Sun Aug 24, 2014 1:46 pm
I have the rover system in my 68 - was straight forward to fit, works pretty well (way better than not having it thats for sure), and is more compact than an aftermarket setup.
You'd probably get the compressor and everything else in with the twinky, but the alternator may be tricky to locate.
PostPosted: Sun Aug 24, 2014 2:40 pm
Thanks Harley...off topic but just noticed you have just had your 10th anniversary of being on the forum!
1965 Riley Elf
1974 Ex Army Moke
1997 Rover Cooper
2002 JCW Cooper
2003 JCW Cooper S
PostPosted: Sun Aug 24, 2014 3:00 pm
Hadn't noticed it myself.
10,000 posts in ten years......worked out nicely!
:D
Users browsing this forum: Bing [Bot] and 312 guests
