It is currently Wed Aug 13, 2025 7:52 am
 Post subject: help for fuel tank
PostPosted: Sun Jun 22, 2014 5:25 pm
As I have a new boot floor fitted can anyone tell me the dimensions for the nut for the fuel tank clamp.
this is the old one. also there is a big hole where tank drain sat is this correct? I did not take measurements :oops:
this is the new floor when I fit the tank I cannot get in to mark where hole should be for the fuel tank clamp.
this is drain fittting for tank it fouls on the floor when the tank is in. thus the hole in the original rusted floor.
any help thanks
 Post subject: Re: help for fuel tank
PostPosted: Sun Jun 22, 2014 6:31 pm
Holesaw the new shiny floor?
Plug the drain?
It's easy once you know how.
PostPosted: Sun Jun 22, 2014 6:34 pm
that's what I what to know is it a wrong fitting?
PostPosted: Sun Jun 22, 2014 6:41 pm
The bolt for the strap, if you shape a point on the end of a bolt you should be able to thread it up from the underside which will dimple the floor where the hole should be. Then drill it out from the inside with out damaging the thread of the captive nut.
PostPosted: Sun Jun 22, 2014 6:44 pm
my current tank has the same drain fitting.
with slightly longer pipe.
PostPosted: Sun Jun 22, 2014 6:51 pm
Captive nut is not there anymore. thus I do not know the position of hole. I was planning to drill and fit a nut sert.
PostPosted: Sun Jun 22, 2014 6:52 pm
does your tank sit up off the floor a bit? would be great if had a picture.
PostPosted: Sun Jun 22, 2014 7:44 pm
will try for one tomorrow, it has some "horsehair" looking stuff between it and the base
the previous tank had no drain and when it ruptured this current one went in roadside I had to drill a hole for the drain.
scary stuff with fuel vapors everywhere.
PostPosted: Sun Jun 22, 2014 10:22 pm
Id be sticking some thing between the floor and bottom of the tank
Mine also had the horse hair stuff like the old heshen carpet underlay stuff in that area
Also wonder how many minis still have this stuff between the rear subframe and under boot floor of body mine has
I managed to get this heshen under lay stuff from a house i tore carpet up at last year they reckon it has asbestos in it when i done a google search about it
PostPosted: Sat Jul 05, 2014 5:04 pm
I checked on an old mini boot with the tank out. and drilled my boot
the hole needs to be 5" (125mm) and 5/8" (16mm) from mounting plate.
if anyone else needs to do this be careful not to let the drill go through too far I put a small mark on the under beaver panel Bugger :cry:
PostPosted: Sun Jul 13, 2014 8:20 am
to seal the fuel tank and not cut a hole in boot floor. I used an old bleed screw. shortened it and cut a groove to tighten in the drain hole seems to seal.
PostPosted: Sat Aug 23, 2014 3:10 pm
well plug didn't seal properly so I decided to cut hole to suit bleed tube.
so I thought I would put the hole position on here to assist anyone else.
2 1/2" across and 1 1/2" down from tank seat.
1" diam hole
worked oout pretty good clearance for plug
I just have to purchase a fuel tank drain plug tube.
PostPosted: Sun Aug 24, 2014 7:37 pm
I just put a grub screw in it with some teflon tape, that was 8 years ago....,
PostPosted: Mon Aug 25, 2014 9:21 am
Dont forget the special grommet that seals the tank to the drain hole!!!!! It will stop water from geting in.
PostPosted: Mon Aug 25, 2014 6:31 pm
wild_willy wrote:
Don't forget the special grommet that seals the tank to the drain hole!!!!! It will stop water from getting in.
Got some blanking grommets will use 25mm wad punch when work out tube centre.
Users browsing this forum: No registered users and 253 guests
