It is currently Sun Aug 17, 2025 1:27 am
PostPosted: Thu Aug 21, 2014 4:35 pm
Hi all,
Does anyone know if you can get original or close to original felt insulated backed vinyl as per the original 850's
I have got some stuff on the engine bay side of the fire wall that i got from Bruce at MG Sports Parts at Thornleigh years ago, but it is quite glossy and i would like it in a mat like finish.
I currently have door trims from Newton Commercial and they are board back vinyl like a deluxe/K/S door trim and i just dont like it that much.
Grant
100% Pure A Series Turbo
PostPosted: Thu Aug 21, 2014 4:42 pm
hi Grant
it would be good if you could send me some pictures of your door trims. As i am just about to purchase some from Newtons.
thanks Gavin
PostPosted: Fri Aug 22, 2014 7:28 am
this is them
http://www.newtoncomm.co.uk/cars/classic-mini/model-19/panels/522-mk1-mk2-mini-door-panels/
new do earlier grey fleck ones but they are all panels and not just the trimto glue to the inner of the door skin
Grant
PostPosted: Fri Aug 22, 2014 7:35 pm
Aussie 850 should have plain trim ,without the ribs,
http://www.newtoncomm.co.uk/cars/classi ... or-panels/
1965 Morris 850
1966 Morris Mini Minor
1967 Morris Cooper 'S'
1977 Leyland LS
PostPosted: Fri Aug 22, 2014 8:20 pm
Boostedmini wrote:
this is them
Grant
yeh I have just ordered those one. I was hoping you had photos of your car with them fitted
PostPosted: Fri Aug 22, 2014 8:22 pm
Were they still on cards or upholstered onto the inside of the outer panels?
Mick
PostPosted: Fri Aug 22, 2014 8:34 pm
Mick
They didn't have door cards ,so the newton ones are not strictly correct, but the plain trim is .
The hessian backing was just glued to the outer door skin and the trim material glued to the hessian
1965 Morris 850
1977 Leyland LS
PostPosted: Fri Aug 22, 2014 8:36 pm
Mick
They did didn't have door cards ,so the newton ones are not strictly correct, but the plain trim is .
Ok, how about the rear, was it the same, and how was it edged ?
I'll have to get my hands on a couple of pieces I think!
Thanks!
PostPosted: Fri Aug 22, 2014 8:43 pm
my 850 had stitched blue trim in the rear and glue hension backed black vinyl in the front.
I liked the look of the stitched front door trims from Newtons. I will soon see what it is like when it arrives :D
PostPosted: Sat Aug 23, 2014 10:06 am
Because the rears are common across all Oz minis your stitched rear sections probably came from a later car. There were no later stitched panels that suited 850 doors so the POs just stuck with the originals.
UK front and rear panels weren't "stitched" rather the lines were formed by frequency welding... That's what you are looking at in the Newton ads.
Cheers, Ian
PostPosted: Sat Aug 23, 2014 11:01 am
[/quote]They did didn't have door cards ,so the newton ones are not strictly correct, but the plain trim is .
The hessian backing was just glued to the outer door skin and the trim material glued to the hessian![/quote]
[/quote]Ok, how about the rear, was it the same, and how was it edged ?
Thanks![/quote]
Rear trims are same as front ,hessian backed glued in place
1965 Morris 850
1977 Leyland LS
