It is currently Wed Aug 20, 2025 3:48 am
 Post subject: 7.9" Vented Brakes
PostPosted: Sat Aug 16, 2014 6:59 pm
Hi guys,
Wondering if anyone is running the 7.9" vented rotors with 4 pot calipers under LP883 or LP918 rims?
Secondly, do you need to alter anything with the hydraulics (master cylinder, bias) when running these?
Thanks
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
 Post subject: Re: 7.9" Vented Brakes
PostPosted: Sat Aug 16, 2014 7:40 pm
I don't think u will be able to run 7.9's under those rims. I'm running vented 4 pot 7.9 brakes and they clear my 10x6 split rims with ease maybe 1/2 inch clearance. I've tried them with a set of contessas and it fits but by the slimmest of margins, maybe a 1mm clearance. Anyway interested to here what others have to say. I think if you search google and look up kad brake template there is a printable drawing which gives you a good idea what brakes will fit. I didn't have to alter anything with my hydraulics. Hope this helps.
1993 R32 Nissan Skyline GTR
PostPosted: Sat Aug 16, 2014 8:34 pm
not a chance....
PostPosted: Sat Aug 16, 2014 10:28 pm
simon k wrote:
not a chance....
Bugger. Looks like the deluxe misses out and the van gets an upgrade with 12s
5/72 Clubman Gt
PostPosted: Tue Aug 19, 2014 8:29 pm
I have a set of contessa's on the shelf, would they fit?
5/72 Clubman Gt
PostPosted: Tue Aug 19, 2014 10:18 pm
I don't think so, wide offset contessas will fit over non-vented minispares 4 pots. I tried some different wheels over some minisport vented 7.9's at Hay last year when Neil from Cooper S Imports had some. None of the 10" wheels I tried fitted
PostPosted: Tue Aug 19, 2014 10:36 pm
Not much point offering 7.9s then. Might as well go with 8.4. :roll:
5/72 Clubman Gt
