It is currently Sun Jul 27, 2025 9:58 pm
 Post subject: No brake lights
PostPosted: Sun Sep 04, 2016 10:00 am
Hey all, just finished a disc brake conversion on my deluxe, and all is running well except the brake lights. Have checked fuses, and cleaned tabs and connectors at the fuses. Any ideas, tips to check?
1967 Morris Mini Deluxe
 Post subject: Re: No brake lights
PostPosted: Sun Sep 04, 2016 10:17 am
Knocked a wire off the brake light switch on the subframe :?:
PostPosted: Sun Sep 04, 2016 10:48 am
The switch might have decided to retire, you can check it with wire across terminals.
PostPosted: Sun Sep 04, 2016 12:33 pm
New hydraulic switches don't seem to last. After buying 2, I fitted a clubby switch to the pedal instead.
PostPosted: Sun Sep 04, 2016 7:49 pm
How'd you mount the clubby switch doc? Do the brake lights only work when the car is running?
PostPosted: Sun Sep 04, 2016 10:31 pm
I bolted a piece of thin steel angle to the pedal box. Brake lights work as normal, with ignition on.
They come on before the brakes build pressure, = safer for the dude behind you than with the hydraulic one.
PostPosted: Mon Sep 05, 2016 8:09 am
Colin Dodds of Sprite Club NSW sold me a good one, not sure if he still has some from the same batch? He tests them all. Give him a ring
http://www.spriteparts.com.au/
PostPosted: Sat Sep 17, 2016 6:50 pm
Thanks goodie, sorry for my slow response, I only got time to check out your suggestion today! Exactly what had happened - wires had worked loose from the switch for some reason. A mate/mechanic from the club had done the conversion and I am still learning the ropes! Appreciate the help and comments from all!
PostPosted: Sun Sep 18, 2016 11:10 am
Gottta love an easy fix :D
