https://ausmini.com/forums/
Right hand tank pattern
https://ausmini.com/forums/viewtopic.php?f=2&t=84662
Page 1 of 2
Author:  womble99 [ Wed Feb 19, 2014 5:40 pm ]
Post subject:  Right hand tank pattern
Has anyone got a pattern / measurements for the right hand tank fitment? I need to cut the hole to fit the tank and want to make sure I get it right :shock:
cheers,
CJ
Author:  guna mk1 [ Wed Feb 19, 2014 5:48 pm ]
Post subject:  Re: Right hand tank pattern
Just trace it on to a piece of paper and reverse it for the right hand side.
I hope that makes sense , when you start doing it you will see how easy it is .
Author:  womble99 [ Wed Feb 19, 2014 6:40 pm ]
that sounds simple enough
Author:  sitnlo62 [ Wed Feb 19, 2014 7:13 pm ]
LOL, Yeh , Simple enough but not correct.
The Right hand tank hole position on a cooper s is not the Mirror Image of the Left hand Side.
Here is what you need................
Author:  Kennomini [ Wed Feb 19, 2014 7:39 pm ]
Why couldn't the BMC make it easy :roll:
Author:  Diesel27 [ Wed Feb 19, 2014 8:06 pm ]
BMC didn't do easy.
Author:  Aussie Brian [ Wed Feb 19, 2014 8:09 pm ]
just checked this layout on my car and it is bang on correct :wink:
Author:  womble99 [ Wed Feb 19, 2014 8:23 pm ]
cheers sitnlo62 I will print that out and take it to the shed :mrgreen:
Author:  coatsie [ Wed Feb 19, 2014 8:51 pm ]
heh heh heh, you are in a class of your own!!!
Author:  Jenk [ Sun Dec 25, 2016 4:12 pm ]
Damn it really... the panel shop doing my car used a template from the left side to do the right side of mine how far out will t be?
Author:  peterb [ Sun Dec 25, 2016 4:34 pm ]
Is the tank in? If so, then close enough. :-) :-)
Author:  Jenk [ Sun Dec 25, 2016 4:46 pm ]
no its not do you think it'll still fit in?
Author:  drmini in aust [ Sun Dec 25, 2016 5:33 pm ]
I did mine mirror image, tank fits but less neck sticks out.
Author:  Jenk [ Sun Dec 25, 2016 6:35 pm ]
That's OK I can live with that... thanks doc.
Author:  winabbey [ Sun Dec 25, 2016 7:47 pm ]
The right hand side tank aperture is 6mm closer to the centre of the car and at the same height as the left hand aperture. Most people putting in a right hand tank just use a mirror image of the LHS so any issues would've shown up by now.
