Engine number https://ausmini.com/forums/viewtopic.php?f=2&t=809 |
Author: | ronniemac [ Wed Jun 09, 2004 12:28 pm ] |
Post subject: | Engine number |
Can anyone tell me the what this engine is out of ? Is it a normal 1275 or something more ? 12YDTaH7022. |
Author: | Meck [ Wed Jun 09, 2004 12:43 pm ] |
12YD/Ta/H 1275 ? Leyland 1275LS (12" Wheels) http://www.hotbricks.org.au/files/engine.txt Cheers Matt |
Author: | bnicho [ Fri Jun 11, 2004 3:05 pm ] |
Leyland 1275 LS start with 12H902.. That hotbricks site is wrong! This engine number equates to a Morris 1100S Morris 1100S actually had a 1275 engine from the factory. Even though the name still has 1100 in it. Some Morris 1100S even have the same small journal crank and rods as a Cooper S! But they still have the solid block with no cam follower covers on the back. |
Author: | Meck [ Fri Jun 11, 2004 3:09 pm ] |
Bugger... sorry 'bout that |
Author: | drmini in aust [ Fri Jun 11, 2004 7:05 pm ] |
Yep, BNicho is right. Morris 1100S. I run one in my car. They have a small journal crank, it's cross drilled but is EN16 steel (not EN40B like an S) and use S rods. I run an S crank in mine. Just had to play about with thrust washer thickness, otherwise it drops straight in. ![]() |
Author: | 9YaTaH [ Fri Jun 11, 2004 10:01 pm ] |
Post subject: | Not to mention the head! |
Author: | drmini in aust [ Fri Jun 11, 2004 10:33 pm ] |
Stock head on 1100S was a 12G940, with 33mm/29mm valves. Some heads had 12G938 stamped next to the thermostat (where most MK2 Ss had 12G1805 stamped). Basic casting was the same for both, but the Cooper S had 35.6 intake valves. Mine now has 35.6/31 valves...and BIG ports.. ![]() |
