Twin carb setup ID please, ? Sports 850 https://ausmini.com/forums/viewtopic.php?f=2&t=79617 |
Author: | phillb [ Fri Dec 21, 2012 9:46 am ] |
Post subject: | Twin carb setup ID please, ? Sports 850 |
I have a set of twin Su on a Peter Manton manifold. Can anyone give me some info on this setup Bowl tags are AUD 368 and AUD 13 Both carbs are AUC 8450 Both bowl lids are AUD 9203 Both bowls are AUC 1390 Thanks in advance ![]() |
Author: | Panthersteve [ Fri Dec 21, 2012 9:47 am ] |
Looks like 2 single carbs on a twin carb manifold to me. |
Author: | Monaco [ Fri Dec 21, 2012 9:56 am ] |
Sports 850 kits were just two individual carbies. In fact the kit only came with the manifold, linkages and one carby with the idea being that they were paired with the cars original. |
Author: | drmini in aust [ Fri Dec 21, 2012 10:04 am ] |
Monaco wrote: Sports 850 kits were just two individual carbies. In fact the kit only came with the manifold, linkages and one carby with the idea being that they were paired with the cars original.
... and from memory the choke only worked on 1 carby, there was no connecting linkage. I used to tune one way back when. ![]() |
Author: | Morris 1100 [ Fri Dec 21, 2012 10:11 am ] |
AUD 13 is a pretty common carby for the 1100 range. (1962 - 1971) AUD 368 is a later 1100 carby fitted to the UK models. (1971 - 1974) That manifold is a bit different in the casting to the usual ones that I have seen. |
Author: | Monaco [ Fri Dec 21, 2012 3:19 pm ] |
Here are the set I have. ![]() |
Author: | XC9000 [ Thu Dec 27, 2012 11:28 am ] |
Post subject: | one-way HS2s |
Phill When you get this sorted, I'd be interested in fitting up some twin 1-1/4"s to a warnerford manifold. I bought some linkages fm Minspares UK and I have not tried to fit them up. I thought I needed symmetrical HS2s to do the job. Anyhow, we'll talk soon re the calendars. Festive greetings, Wayne |
Author: | goodie [ Fri Jun 30, 2017 8:53 am ] |
Post subject: | Re: Twin carb setup ID please, ? Sports 850 |
Did these 850 Sports Twins come only with a Manton manifold or something else? |
Author: | minimans [ Fri Jun 30, 2017 9:03 am ] |
Is it this? Attachment: monaro.JPG
Author: | drmini in aust [ Fri Jun 30, 2017 9:06 am ] |
Yes that was Manton. These 1100 and 850 kits were much the same, from memory. |
Author: | timmy201 [ Fri Jun 30, 2017 10:15 am ] |
There are a couple of old posts about the Sports 850, from what the user "Sports850" says here the manifold type changed depending on the dealer that installed it: viewtopic.php?f=9&t=34556&hilit=manifold Mini experience also has an article on them https://pocketmags.com/au/the-mini-expe ... ne/issue-5 |
