https://ausmini.com/forums/
massive flat spot & won't rev
https://ausmini.com/forums/viewtopic.php?f=2&t=787
Author:  Rupert [ Mon Jun 07, 2004 8:04 am ]
Post subject:  massive flat spot & won't rev
My mate has a rebuilt 1293 that is a bit worked, problem is that it has a massive flatspot when putting your foot down and it seems to die off and won't rev above 5500 rpm.
It only running a 1.5 inch SU (fully rebuilt) at the moment but will swap to twins soon.
Also has a standard 998 non-vacuum adv dizzy.
Ideas?
Author:  minitec [ Mon Jun 07, 2004 8:44 am ]
I think carb. Get it on a dyno.
Author:  poeee [ Mon Jun 07, 2004 9:12 am ]
I've just had carbie problems, and it sounds like it could be that.
That dizzy maybe the problem, but i'm no expert when in this area.
Author:  gafmo [ Mon Jun 07, 2004 9:17 am ]
I'v also had a simmilar problem. I checked everything from the fuel pump to blowing out the HIF44. Then I checked all the Elec Changed the points and condencer. It turned out after fitting the new point they were then closing again. I could not understand it. I would ajust the gap and then the same thing would happen. Thinking They were fine I went onto the next area. Try your points.
Gamfo
In the Hills
Author:  drmini in aust [ Mon Jun 07, 2004 7:24 pm ]
The reason new points close up is lack of lube on the cam, usually. This wears the points rubbing block.
Smear a little HMP grease on the cam. :wink:
