Deseamed Mini - a good base for my project? Or avoid? https://ausmini.com/forums/viewtopic.php?f=2&t=78312 |
Page 1 of 2 |
Author: | ten_sim [ Tue Sep 04, 2012 10:09 am ] |
Post subject: | Deseamed Mini - a good base for my project? Or avoid? |
Going to be building an R1 powered Mini over the next 12-18 months ( ![]() "The work was carried out at Tony Carrol's, Panelbeater of Nelson Bay. First the seams were cut away in small sections throughout their length in sections of approx 2.5 to 3 inches in length ( somewhat resembling castelations) so all the various panels remained firmly fixed in their origional position. Then each cut away section was welded together by using a small tacking run technique so as to avoid any possible heat distortion of the panels. When these sections were completed each of the remaining seam section was individually removed in turn, again not working in close together areas, and that section also welded in the previously described manner. All welding was carefully carried out using a varying direction process and with very short application timeing so as to avoid any distortion whatsoever and none resulted. This whole welding process was carried out with a constant and continual check being made of the temperature of each metal panel. The complete seams have been totally welded all along their full lengths and this process took two full days to complete. The vehicle was then filled and faired to act as a mould." So it sounds like they knew what they were doing and did a good and proper job? There are no front guards with the shell, but I was planning on a Carbon Fibre 2 piece front anyway (to get weight down), so I don't think this will be a big issue? Waddayareckon chaps? ![]() Mini_3 by ten_sim, on Flickr ![]() Mini_1 by ten_sim, on Flickr ![]() Mini_2 by ten_sim, on Flickr ![]() Mini_7 by ten_sim, on Flickr ![]() Mini_4 by ten_sim, on Flickr |
Author: | Panthersteve [ Tue Sep 04, 2012 10:15 am ] |
It has no boot ![]() How do you get the fuel tank in ![]() How do you get to the battery or is it now somewhere else, where ![]() |
Author: | ten_sim [ Tue Sep 04, 2012 10:17 am ] |
So it doesn't! I didn't even notice that, ![]() ![]() ![]() |
Author: | John Smidt [ Tue Sep 04, 2012 11:07 am ] |
That is a 1977-1978 shell so check carefully for rust |
Author: | qa50 [ Tue Sep 04, 2012 11:14 am ] |
Id be very careful. Gotta remember they deseamed that shell for one purpose only - to make a plug for a mould. Who knows what's really under the bog? |
Author: | Panthersteve [ Tue Sep 04, 2012 11:26 am ] |
qa50 wrote: Id be very careful. Gotta remember they deseamed that shell for one purpose only - to make a plug for a mould. Who knows what's really under the bog?
I was thinking the same, why go to all that trouble of welding the way they said just to make a mold. ![]() |
Author: | ten_sim [ Tue Sep 04, 2012 11:49 am ] |
Quote: That is a 1977-1978 shell so check carefully for rust Is it that late a model? I thought it was more a 60's shell, how do you tell the difference? Quote: why go to all that trouble of welding the way they said just to make a mold
He was (supposedly) going to do a VTEC conversion on it, apparently... I'm up in North QLD and the car is located on the Central Coast NSW, so I can't inspect just now (though my in-laws are only an 1-2hrs away so my father-in-law could check it out maybe... Only looking at spending $500-$750 on this, not massive money... |
Author: | GtiMini [ Tue Sep 04, 2012 11:49 am ] |
I'm a fan of deseamed mini's. Had a few and done a few myself. As a matter of fact I've got one now. Done correctly there should be no strength issues and they are probably stronger that original. But, I'm not a fan of deguttering the roof. It does something that (to me anyway) seems to ruin the look of the car. |
Author: | awdmoke [ Tue Sep 04, 2012 11:55 am ] |
ten_sim wrote: Quote: That is a 1977-1978 shell so check carefully for rust Is it that late a model? I thought it was more a 60's shell, how do you tell the difference? It doesn't have the Rotodip post holes in the firewall and rear seat panel. I also like (& have one) deseamed minis. Be certain of what's under the filler! |
Author: | John Smidt [ Tue Sep 04, 2012 12:05 pm ] |
ten_sim wrote: Quote: That is a 1977-1978 shell so check carefully for rust Is it that late a model? I thought it was more a 60's shell, how do you tell the difference?[quote On the very late Australian models, they no longer had the hole in the front or rear for rota dip |
Author: | ten_sim [ Tue Sep 04, 2012 12:26 pm ] |
Ah, I see, good to know! Didn't realise they made Aussie round-noses that late, thought they were all Clubmans in the '70's! |
Author: | Panthersteve [ Tue Sep 04, 2012 12:28 pm ] |
ten_sim wrote: Ah, I see, good to know! Didn't realise they made Aussie round-noses that late, thought they were all Clubmans in the '70's!
they didn't, they were all square shaped "clubmans" after mid '71. This is one of them, the externally obvious difference once the front has been removed is the tail lights, which of course this doesn't have. |
Author: | John Smidt [ Tue Sep 04, 2012 12:32 pm ] |
That is a clubman shell, I think he was going to put a round nose on it and a few people have done this |
Author: | ten_sim [ Tue Sep 04, 2012 12:34 pm ] |
So the bonnet is not correct for this shell? Can you just stick an older roundnose bonnet on a Clubman? Are the subframes the same over the years (thinking about the R1 conversion here...) |
Author: | Panthersteve [ Tue Sep 04, 2012 12:40 pm ] |
ten_sim wrote: So the bonnet is not correct for this shell? Can you just stick an older roundnose bonnet on a Clubman? Are the subframes the same over the years (thinking about the R1 conversion here...)
Yes the bonnet could be used but only if the rest of the front end used was also roundnose. The subframes are the same, the changes that were possible were hydro or rubber cone suspension but you could fit either to the shell as long as you had all the associated pipes etc if hydro was wanted |
