It is currently Sat Jul 26, 2025 2:59 am
 Post subject: Rear brake drums
PostPosted: Sun Sep 02, 2012 2:02 pm
Got my mini through the Road Worthy Certificate the other day with a set of borrowed rear brake drums. Couldn't use mine as they're standard and I needed the ones with the built in spacer. Anyway, in a bit of a hurry changing them back the other day and I had to force them on. The adjusters are completely un-done and the hand brake cables have been loosened, but the brakes are still binding and I can't get the drums off.
Any suggestions or thoughts please?
Rod Image
PostPosted: Sun Sep 02, 2012 7:35 pm
dunno why they're stuck on, but put a wheel nut on backwards on each stud (to protect the thread) and tap on them with a hammer, the drum will jiggle off
PostPosted: Sun Sep 02, 2012 8:14 pm
Maybe the brake shoes are oversize? And the drums are standard?
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Mon Sep 03, 2012 5:45 pm
Hah........got 'em off. They just needed the usual hammer trick. Just needed a bit more 'time' than what I had the other day :)
Rod Image
PostPosted: Mon Sep 03, 2012 5:55 pm
Worst ones I ever had to remove were on Spiro the Moke, years ago. Had been rusted still for 10 or 20 years, wouldn't move at all so I got the angle grinder out and split em off.
:P
PostPosted: Tue Sep 04, 2012 5:43 pm
Haha......Spiro strikes again. You didn't have a big enough hammer Kev.......your FBH was too small :)
Rod Image
