Timing cover bracket https://ausmini.com/forums/viewtopic.php?f=2&t=78285 |
Author: | Kennomini [ Sun Sep 02, 2012 12:58 pm ] |
Post subject: | Timing cover bracket |
Dose anyone have an idea what this plate/bracket would be for on this engine? ![]() ![]() It's bolted behind the timing cover and has curved rubber pads on each side of the engine. I've never seen anything like it before and it looks more like a "factory" item and not some home built thing. |
Author: | Morris 1100 [ Sun Sep 02, 2012 1:11 pm ] |
It is the engine mount for a Morris 1100. |
Author: | drmini in aust [ Sun Sep 02, 2012 2:00 pm ] |
... also Morris 1100S. For use in a Mini just take Mr Anglegrinder or Mr Oxy and cut both the sides off it. |
Author: | TheMiniMan [ Sun Sep 02, 2012 2:15 pm ] |
&,,, if you have a look at the diff housing it will have 4x coarse thread (UNC) """side""" bolts for the shifter "Sandwhich-mount" to bolt to & also--> the diff ratio will most probably be a 4.1:1 or a 4.2:1 & ![]() |
Author: | drmini in aust [ Sun Sep 02, 2012 2:23 pm ] |
...and the gearbox is 3 synchro with the usual (non-S) crap ratios. POS these days, find a Mini K 4 synchro box and use that (but put S gears + a 3.44 diff in). ![]() |
Author: | Kennomini [ Sun Sep 02, 2012 4:12 pm ] |
what is the easiest way to tell what diff ratio a box has? |
Author: | drmini in aust [ Sun Sep 02, 2012 4:32 pm ] |
Kennomini wrote: what is the easiest way to tell what diff ratio a box has?
If it's off the motor, count the pinion teeth and crownwheel teeth. A spot of white paint on a tooth makes it easy. 18/62 is a 3.444 17/62 is a 3.647 17/64 is a 3.765 If the pinion is 15T, it's either a 4.13 or a 4.26. Too low geared for a Mini (or a Moke on 10" wheels) |
Author: | Kennomini [ Sun Sep 02, 2012 5:00 pm ] |
drmini in aust wrote: Kennomini wrote: what is the easiest way to tell what diff ratio a box has? If it's off the motor, count the pinion teeth and crownwheel teeth. A spot of white paint on a tooth makes it easy. 18/62 is a 3.444 17/62 is a 3.647 17/64 is a 3.765 If the pinion is 15T, it's either a 4.13 or a 4.26. Too low geared for a Mini (or a Moke on 10" wheels) Those ratios are great, is their a list of the complete ratio range for minis and mokes? Also how do you figure out what RPM you'll do at 100kmph with a particular diff ratio? |
Author: | drmini in aust [ Sun Sep 02, 2012 6:51 pm ] |
That shown above ^^^ is pretty much the whole range that was sold over here. There are a few others available from UK: 4.33 3.938 3.211 3.105 2.95 2.76 with 10" wheels, 3.444 diff is about 16.1 MPH/1000 3.647 diff is 23.91 KMH/1000 (calcs from my GPS, 4600 rpm @ 110KMH) |
