wheel alignment https://ausmini.com/forums/viewtopic.php?f=2&t=78281 |
Author: | min-E [ Sun Sep 02, 2012 8:33 am ] |
Post subject: | wheel alignment |
Hey guys I'm in need of an alignment as my front wheels are getting worn out way too quick. Being a bit of a noob what's the appropriate settings ie camber? I'm not running any upgraded suspension or steering just the old shocks atm. Cheers |
Author: | John Smidt [ Sun Sep 02, 2012 9:17 am ] |
If It has standard Mini suspension You Can only adjust toe in toe out, however check for bent arms and worn rubbers |
Author: | Convertible Mini [ Sun Sep 02, 2012 9:19 am ] |
Post subject: | WHEEL ALIGNMENT |
Make sure all rubber bushes are not perished or worn and suspension not too low otherwise it will be a waste of time aligning the wheels. |
Author: | min-E [ Sun Sep 02, 2012 9:22 am ] |
How can I adjust the toe in/out. All new rubbers and bushes. |
Author: | meeni [ Sun Sep 02, 2012 4:38 pm ] |
the tie rod ends on the steering rack control toe adjustment. its really something that needs to be done by a pro if your not sure as mis alignment can cause serious tyre wear and handling issues.. take it to a tyre shop and they should be able to sort it out for you |
Author: | min-E [ Sun Sep 02, 2012 6:40 pm ] |
Cheers |
