It is currently Wed Jul 16, 2025 12:38 am
 Post subject: SU fuel pump ticking
PostPosted: Thu Aug 30, 2012 11:34 pm
Hi guys. Changed the fuel hoses over. The S ticks quickly for .3 secs then it ticks once every 5 secs or so. I am presuming It's keeping pressure upto the carbs There's no leaks. I am presuming its normal.. I haven't started it yet.
PostPosted: Thu Aug 30, 2012 11:39 pm
Sounds about right. That's what mine always did.
PostPosted: Fri Aug 31, 2012 10:10 am
That sounds like mine too
1964 998cc Cooper
1971 Mini K x 2
1972 Clubman GT
PostPosted: Fri Aug 31, 2012 10:32 am
Ditto. All good :D
PostPosted: Fri Aug 31, 2012 11:12 am
Thanks guys.. I normally don't hear the other ticks as the motor is running... Just working on the car engine bay with out the motor running
 Post subject: SU PUMPS
PostPosted: Sat Sep 01, 2012 6:03 am
SU Pumps only tick when fuel pressure drops. That is the way they work.
"Let us remove your "SHORTS"
PostPosted: Sat Sep 01, 2012 8:13 am
One of those idiosyncrasies of the Mini that make it unique :wink:
