1100 block. https://ausmini.com/forums/viewtopic.php?f=2&t=78243 |
Author: | Speedwell Racer [ Thu Aug 30, 2012 9:37 am ] |
Post subject: | 1100 block. |
Hey Guys, Just wondering if an 1100 block bored 40thou over (not used since) with new cam bearings is worth $100? It doesnt come with crank or piston but i think its cheap for an imacculate block.. What do i look at as to why it could have been bored? Owner doesnt know why it was bored because he brought it and hasnt used it. Where do i look for cracks etc? Any help appreciated, i just dont know a whole lot about blocks. Cheers, Rhys |
Author: | minimy [ Thu Aug 30, 2012 10:57 am ] |
hey rhys,100 bucks is a good price,but only if it comes with the original main crank bearing caps. |
Author: | Speedwell Racer [ Thu Aug 30, 2012 2:14 pm ] |
Is it useless without them Andy? |
Author: | drmini in aust [ Thu Aug 30, 2012 2:33 pm ] |
Speedwell Racer wrote: Is it useless without them Andy?
Without the original caps it is a doorstop. They were line bored to size, with the block. They are not interchangeable. It is possible to buy new steel caps (or grind a bit off some S/H ones) then line bore the block again, however this is expensive, shortens the crank to cam C/S a bit, and the chain will be loose unless a tensioner is fitted (more expense). If no caps, go find another 998 or 1098 block.. plenty about. You should be able to get a dead one with crank and all for a hundred or so. As for why it was bored then left, perhaps it was done first then the owner realised the `no caps' problem. |
Author: | Speedwell Racer [ Thu Aug 30, 2012 2:37 pm ] |
well i am picking up a few other bits and pieces from a mate which includes a dead 1100 on a subby. So if it doesnt have caps im better off rebuilding the dead one.. |
