https://ausmini.com/forums/
Engine Number
https://ausmini.com/forums/viewtopic.php?f=2&t=766
Author:  Stillson [ Fri Jun 04, 2004 12:45 pm ]
Post subject:  Engine Number
Very stupid! Where is the engine number on a 1275?
Author:  sweep77 [ Fri Jun 04, 2004 12:58 pm ]
should be on the top and front of the block me thinks. just under the coolant temp sender. unless it has been machined off in the past.
ash
Author:  Stillson [ Fri Jun 04, 2004 1:42 pm ]
So now I feel really stupid, I have a feeling that the bloke that I bought my mini off has told me a lie, the engine number on the block is 99HE22 108412, does that make it a 998 engine not a 1275. The chassis number is 021 D2S2M10/8955, what does that mean?
Author:  sweep77 [ Fri Jun 04, 2004 3:43 pm ]
unfortunately thats what it looks like. According to my info its a 998 A+ block with dished pistons. The chassis number refers to a 998 leyland mini sedan. What does anyone else think? Maybe the guy you bought it off had been told the same thing. Guess it just pays to check everything out before buying a mini. Hope this helps.
ash
Author:  Stillson [ Fri Jun 04, 2004 4:52 pm ]
Thanks Ash, as I said I am new to this and I was told when I bought my ride it was a clubman with a 1275 but thanks OK. Life will go on!!
TA!
Author:  Mini Smeg [ Sat Jun 05, 2004 10:10 pm ]
You should go back to him andrew. Ring his neck at least :)
Author:  Mike [ Sun Jun 06, 2004 5:33 am ]
Thats why when you buy a car get them to write you out a receipt with a comprehensive listing of everything they say is in it, the ammount you paid for it, their statement that no money is owed on the car etc.
Plus isnt there a week long cool off period when you can return a car (even private sale) as ong as it wasnt an auction?
Author:  Gordie [ Sun Jun 06, 2004 9:35 am ]
it still could be a 1275, i know of a couple that have been stamped with the orignal engine number for the car, ie 99h, so they wouldnt need to pay more for insurance and disc brakes. check if it has the two removable covers on the back of the engine or not, and count the number of head bolts.
hope this helps
Author:  Mini Smeg [ Sun Jun 06, 2004 9:44 pm ]
Hey gimme a drive in ya back yard I will be able to tell you if its a 998 or 1275 :wink:
Author:  Stillson [ Mon Jun 07, 2004 5:00 pm ]
(Writing with very stupid look!) Could someone explain the difference in head bolts!!
You could drive it around the yard Scott, but a bit hard with no interior or electrics :P
Author:  drmini in aust [ Mon Jun 07, 2004 8:49 pm ]
Cooper S had the normal 9 head studs, plus an extra one at the back, and a bolt at the front (ie. one each end of rocker cover)
Another easy way to check is the heater outlet- if the flange on back of head is mounted at an angle it's a 1275, if mounted square to head its a 998 or 1098 (or 850...!).
As posted above, yes it's illegal, but some people have been known to alter the engine number to avoid fitting discs, or getting inspection for engine change.... :roll:
Author:  Mini Smeg [ Mon Jun 07, 2004 11:05 pm ]
I texted you the other night and got no reply you sure you gave me the right number?
Author:  Stillson [ Tue Jun 08, 2004 8:53 pm ]
I got your message but was out, come over tomorrow arvo! send me another text or ring if you want to.
Author:  Mini Smeg [ Tue Jun 08, 2004 10:58 pm ]
Ok might be with my mate dicko but try come over after 5pm.
