Gears... https://ausmini.com/forums/viewtopic.php?f=2&t=761 |
Author: | willy [ Thu Jun 03, 2004 9:34 pm ] |
Post subject: | Gears... |
...tick knob. Can someone tell me the thread size on the clubman gear lever. I want to make a threaded insert for this nice leather thing i bought. I'd glue in a small tapped rod so i can screw it nice and tight... the self cutting plastic one it comes with turns round and round so easily. If someone knows the size, i can whip one up tomorrow in metal work. ![]() Cheers. |
Author: | poeee [ Thu Jun 03, 2004 9:39 pm ] |
If no one knows, go down to ya local nuts and bolts store with a standard knob, and try some bolts in it. ![]() |
Author: | willy [ Thu Jun 03, 2004 9:58 pm ] |
Yep good idea ![]() Pity theres no hardware stores open at 10pm and my range of assorted bolts is quite limited. Anyone? Will. |
Author: | drmini in aust [ Thu Jun 03, 2004 10:15 pm ] |
(guess...) 3/8" UNF?? ![]() Try a Mini head nut if U got one spare... <edit> Nope, I just looked at an old one- looks like 5/16" UNC or M8- bit hard to tell in the dark.. |
Author: | poeee [ Thu Jun 03, 2004 10:37 pm ] |
I've got a knob infront of me, it's definatly not a fine thread! |
Author: | tzi [ Fri Jun 04, 2004 10:04 am ] |
make a sleeve and chuck a pointed grub screw in the side. my g/f's gear knob is a solid stainless ball, and it hasnt moved since I put the pointed grub screw in it (threw away the one it came with) |
Author: | dr trim [ Fri Jun 04, 2004 10:59 pm ] |
measure it? ![]() |
