It is currently Mon Jul 21, 2025 10:41 am
PostPosted: Mon May 01, 2017 8:47 am
I am looking for a UK Primary Gear Service Bulletin No GN/92 it was published about 1961 2-3.
It may not have been published in Australia.
PostPosted: Mon May 01, 2017 9:32 am
Is that the one about converting the early wet tail crank to take the later dry type primary gear?
PostPosted: Mon May 01, 2017 12:01 pm
Correct Dr Mini
PostPosted: Mon May 01, 2017 12:23 pm
Don't have copy but I remember it involved punching a .080"? diameter brass plug in when I did it.
PostPosted: Mon May 01, 2017 12:31 pm
Thanks for the Info.
Les
PostPosted: Mon May 01, 2017 1:00 pm
Service Bulletin GN/92 was issued by BMC UK. The equivalent BMC Australia Bulletin is C236 (see below). Is this what you are after?
PostPosted: Mon May 01, 2017 2:43 pm
Thank you for the Info, its what I was after.
Thanks again.
Les
PostPosted: Mon May 01, 2017 4:08 pm
Your a champion Doug
Users browsing this forum: BrisbaneMini and 100 guests
