Some info on this twin carb setup? https://ausmini.com/forums/viewtopic.php?f=2&t=69080 |
Author: | poeee [ Sat Feb 26, 2011 4:07 pm ] |
Post subject: | Some info on this twin carb setup? |
I don't normally buy 'twin carbs' made up of two singles carbs, but I bought these because it was so complete and simply looked right, even down to one of the air cleaners having a perfectly located breather inlet (or outlet??). ![]() What appears to be purposely made bracketry for throttle and choke. ![]() Breather ![]() No markings on the manifold. ![]() Different bowls? ![]() Linkage. ![]() |
Author: | david rosenthal [ Sun Feb 27, 2011 1:27 pm ] |
the carbys are off different models. The one on the right[viewed from under- neath ] looks like it's a early 850 or minor carby. The bowl is at a different angle so could be a minor carb. The manifold looks like the ones that were around many years ago as this was a fairly std set up with same carbs. a lot of work re-building them. |
