SU Oil? https://ausmini.com/forums/viewtopic.php?f=2&t=689 |
Author: | poeee [ Sat May 29, 2004 11:05 am ] |
Post subject: | SU Oil? |
I'm gunna freshen up the oil (or top up, there might not be any in there, lol) in my twin 1.25" SU's, and I was wondering what oil to use? I have heard engine oil isn't good at all for them. |
Author: | drmini in aust [ Sat May 29, 2004 11:40 am ] |
Most common are 20W/50 motor oil, or ATF (Dexron 2 or 3) ![]() |
Author: | Bent'S [ Sat May 29, 2004 1:50 pm ] |
Try using motorbike fork oil. Its about 10W and still lubricates well |
Author: | poeee [ Sat May 29, 2004 1:58 pm ] |
I got some general house oil stuff from AutoPro, it's what they recomended me. The car is going in to get the twins tuned soon at "rally carb" here in Geelong, so I guess they will put the right stuff in then. |
Author: | Mike [ Sat May 29, 2004 2:46 pm ] |
In the UK they were using very light oil like sewing machine oil (and I think thats what Haynes recomend) but in Aust. where its much warmer, normal engine oil (which is the 20/50 the Dr is refering to) should be fine. Just make sure to get the oil into the chamber (cant remember the name for the life of me) rather than around it. And you only need a few drops. |
Author: | tzi [ Sat May 29, 2004 9:13 pm ] |
i've been told that a light oil works best.. and one person ever recommended wd-40 ![]() ![]() |
Author: | poeee [ Sat May 29, 2004 9:48 pm ] |
lol, while searching bunnings for something (we had no luck at supercheap, so went to bunnings which is in the same complex), my father said "you could always use WD-40." ![]() |
Author: | Animal [ Sat May 29, 2004 11:30 pm ] |
20 yrs on the job and have only ever used 'singer machine oil' its cheap, 10w, and readily available, comes in those handy oil bottles. I would'nt recomend motor oil as its to heavy and affects the dash-pot piston raise and drop speed which will cause your motor to run lean on accel and over-run on decel. |
Author: | kazjim [ Sat May 29, 2004 11:55 pm ] |
Sorry Animal, but "which will cause your motor to run lean on accel " ...... Isnt the point of the Dashpot oil to DAMPEN the movement, so that when there is a drop in vacuum (as in accelleration) the dashpot wants to raise very quickly, but the heavy oil slows it down, raising the airspeed over the bridge of the carb, increasing the "accellerator pump" effect ..... RICHENING the mixture ? I know mine is a lot nicer in start stop traffic with a heavier oil (Penzoil 20/50) than a light one (ATF / Marvel Mystery oil) Just simple physics........... J |
Author: | Animal [ Sun May 30, 2004 12:04 am ] |
true true...but with the thicker oil air speed is increased but the needle is slower to retract which will decrease fuel supply...have tested with air/fuel meter on diag mach and although common sense says otherwise, accel is lean with thick oil.... ![]() |
Author: | Anto [ Mon May 31, 2004 7:31 pm ] |
I run 3in1 oil and a red spring in my single HS2 carb (with quick-lift piston) and I think it's great - very responsive. You do notice a very slight flatspot, because of the lack of 'accelerator pump' function caused by a thicker oil - but I tune a little on the rich side so it isn't a problem. I tried 20w50 once, round the block, and the car was S.L.O.W! It made a serious difference. I noticed that even with ATF it was a bit slower - but I guess playing round with needles I could fix that. |
Author: | spathi [ Mon May 31, 2004 8:16 pm ] |
We've always used singer sewing machine oil here and never had any problems. I just used it as thats what my father always used when it was his car... seems to work tho ![]() |
