It is currently Sat Jul 26, 2025 9:44 am
Post new topic Reply to topic  [ 43 posts ]  Go to page 1, 2, 3  Next
 Post subject: Coolant Type
PostPosted: Sun Jan 02, 2011 2:26 pm
What is the best option for coolant in a Mini used in warmer (and non-freezing) conditions?
I understand the ethylene glycol used in some coolants reduces the heat transfer rate, thus reducing its efficiency to cool the engine.
The upside of the ethylene glycol is that it increases the boiling point a bit, but hopefuuly we don’t get that hot.
Any recommendations?
PostPosted: Sun Jan 02, 2011 2:33 pm
I use Nulon ethylene glycol (25%) in my 1412 and 1360 motors, neither has ever overheated. Radiator is a stock 1970 Oz one (16 fins/inch) and a MiniMatic heater.
[edit] rad cap is 82°C
Last edited by drmini in aust on Sun Jan 02, 2011 4:13 pm, edited 1 time in total.
PostPosted: Sun Jan 02, 2011 3:49 pm
Now that my radiator cap actually fits ( the most ignored part of the process when looking at overheating !!! ) , I,m using 30 % Rust Inhibitive , 20 % Coolant and 50% water , my system is stable , no problems , the only time its got past halfway on the gauge was a warm day stuck in traffic
13 pound cap
82deg thermostat
PostPosted: Sun Jan 02, 2011 4:33 pm
Mods rock!
If your running one of those (aweful) alloy radiators, the choice of coolant is critical. If your running the stock copper job, then most coolants will be quite OK.
PostPosted: Sun Jan 02, 2011 4:44 pm
A while back I had a brain fart as I mixed poured my castrol glycol concentrate into my radiator. I was aiming for a 50:50 ratio of glycol and water, but poured in 2.5 litres of glycol instead of 1.5. This meant that less than a litre of water went in, and the ratio was up around 5:6.
I drove it for a couple of weeks before I put it back to rights (I was pressed for time during uni, and had to come up with a clean solution to retrieve the wasted glycol). I have some very accurate digital gauges installed in my car and I was able to see the difference straight away. I found that yes, the car ran hotter, but not by much. About 2-3 degrees was the maximum change. There were hot days in there as well, but the temperature remained stable at the slight increase. It wasn't anything to get concerned over I suppose, but it's not worth wasting the expensive glycol anyway.
 Post subject: Best Coolant
PostPosted: Mon Jan 03, 2011 8:50 am
The best one I have found is the one sold by Toyota. It is red and does not EAT at any alloys when it meets with Air. Most others I stay way from regardless their "pretty colours". They act like an accumulator from the tests we have done. You get what you pay for.
"Let us remove your "SHORTS"
 Post subject: Re: Best Coolant
PostPosted: Mon Jan 03, 2011 6:47 pm
make sure you get the concentrated one from Toyota, the one you mix 50/50 with demin water... their new premix is a ripoff and not as good :D at least that's what the spare parts guy at my local dealer tells me - he thinks it's hilarious i spend the dosh on their good coolant for a 40 yr old car....
PostPosted: Mon Jan 03, 2011 6:55 pm
What is the dosh for the Toyota stuff anyway?
Its a little less than 15 dollars per litre for the Castrol coolant.
PostPosted: Mon Jan 03, 2011 7:07 pm
you like them that much you are in awe of them?
:roll:
tim
PostPosted: Mon Jan 03, 2011 7:09 pm
Mods rock!
Mick wrote:
................ Castrol coolant.
I had this in an engine that was stored for just on 28 years. I was expecting the absolute worst when I pulled the drain plug on the block, but was very pleasantly surprised when it came out green and on pulling the welsh plugs the block was still grey inside - no rust at all!
PostPosted: Mon Jan 03, 2011 7:15 pm
Mods rock!
:roll:
Yeah, it really Awes me every time I see them split, crack and corrode to the point of choking! That is really one of them 'Awe-shit, again!' moments......
PostPosted: Mon Jan 03, 2011 7:17 pm
GT mowog wrote:
:roll:
I hate the way that the little radiator places are all closing due to the cheap Chinese imports. :cry:
PostPosted: Mon Jan 03, 2011 7:21 pm
Mods rock!
GT mowog wrote:
:roll:
Out of curiosity, how old is the copper one in your Morris 1100?
PostPosted: Mon Jan 03, 2011 7:26 pm
GT mowog wrote:
GT mowog wrote:
:roll:
44 years old. I have not touched it in the 12 years I have owned the car. I don't know if it has ever been out. It looks like the original core.
PostPosted: Mon Jan 03, 2011 7:28 pm
Mods rock!
Hmmmm....I'd like to see one of those chinalloy radiators go 4.4 years.......
Even BL learnt the hard way. The first Metros had alloy radiators, they soon went back to copper.......
