It is currently Wed Jul 30, 2025 5:20 am
 Post subject: Shaped window seals
PostPosted: Mon Jan 10, 2011 10:19 am
Does anyone know where I can get front and rear shaped window rubbers?
The ones I have are straight and will just bunch up in the corners.
Thanks.
:D
PostPosted: Mon Jan 10, 2011 10:40 am
Mods rock!
That usually happens when your they are too long. Most are 'off the roll' and they always give you that bit extra, which needs trimming. Also, keep in mind that the MKII on, UK rear windows are bigger than ours and the rubbers seem to always be cut for the UK cars.
PostPosted: Mon Jan 10, 2011 9:20 pm
I've had Windscreen O'Briens install the front & rear screens on 4 different cars over time, and had them supply the front & rear rubbers to suit, which were the correct size, one piece and shaped. Fitted perfectly.
Steve
PostPosted: Mon Jan 10, 2011 10:16 pm
I got a quote off them, they wanted $500 labour to install the windows plus the cost of any seals / windows.
I was hoping to find the right seals somewhere and even give it a crack myself, even just one window.
:D
PostPosted: Mon Jan 10, 2011 10:20 pm
I think the seals Heritage MG sell are shaped and moulded together at the right lenth. $500 bucks is rediculous. Our local guy charges us $50 to remove and replace a mini windscreen if we don't feel like doing it.
And you should imo have a go, there are some other threads on here about doing it and its not that hard. Just go easy on the glass. Have a crack but don't crack it! :D
PostPosted: Mon Jan 10, 2011 10:32 pm
Anyone tried the rover front windscreen seals? They have a wider section of rubber than early cars and are supposed to seal better.
PostPosted: Mon Jan 10, 2011 11:42 pm
:D
WTF, $500, they're on drugs, or should be! Never cost me any where near that.
Did you ask them about supplying just the seals?
Steve
PostPosted: Tue Jan 11, 2011 3:53 am
:P
PostPosted: Tue Jan 11, 2011 3:54 am
:roll:
PostPosted: Tue Jan 11, 2011 3:58 am
Those window seals do the job Harley.
Before I moved I got a new front w/screen (they supplied) without the top tint and had both front and rear windows fitted (I supplied new window seals and locking strip for about $325 . . .
http://www.nationalwindscreens.com.au/
PostPosted: Wed Jan 26, 2011 7:08 pm
[quote="mini_mad_matt"]I think the seals Heritage MG sell are shaped and moulded together at the right lenth. $500 bucks is rediculous. Our local guy charges us $50 to remove and replace a mini windscreen if we don't feel like doing it.
I'm in Brisbane - can you please tell who the $50.00 man is, as I need front and rear screens fitted.
No decision is incorrect when made - but it does become apparent in retrospect...
PostPosted: Wed Jan 26, 2011 7:43 pm
The $50 man probably won't be that cheap for you as thats trade price and in his local area, but he is still really good. I was just looking through yellow pages and i'm pretty sure he is River City Auto Glass 0412 303 826. He is on the southside though(Logan), name is Gary, highly recommend him.
