It is currently Mon Jul 28, 2025 5:19 am
 Post subject: Motor Freight
PostPosted: Tue Jan 25, 2011 9:48 am
Whats the bets way to freight a motor.
Ill be using e-go couriers.
Is it best to just stick it on a pallet and be done with it, or would couriers take it If I wrapped it like a parcel.
Whats a 1100s short motor weigh?
PostPosted: Tue Jan 25, 2011 11:27 am
Must have a pallet so they can lift it, as it's about 90kg - but don't quote me on that!
PostPosted: Tue Jan 25, 2011 11:39 am
I thought they were closer to 120kg.
But a pallet i would say is a must.
Maddmatt couriered me a twinky engine on a pallet with TNT, cost me i believe $150 from QLD to sydney
You're so square
Baby I don't care
PostPosted: Tue Jan 25, 2011 11:41 am
I paid just over 80 dollars for full pallet with ...
My Stroker motor (complete)
2 extra blocks
2 extra cranks
various ancillaries.
Adelaide, SA To North Rocks, NSW....
Just the motor was mine, the other bits were an Nb racing guys stuff... going to the same place 8)
PostPosted: Tue Jan 25, 2011 12:22 pm
e-go requires an engine to be drained of oil and strapped solidly to a pallet if over 35kg (I guess if it was from a motor scooter...). They quoted me $120 extra to send out a truck with a tailgate lift thing unless a forklift is available on site. They may be able to manage with a pallet dolly if using a tail lift but they were a bit non-specific about this when I asked them.
Its probably good manners to wrap it in glad wrap if its really greasy, and likely to mean that its treated a little more respectfully (i.e. only drop it 5 feet instead of 6).
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Tue Jan 25, 2011 3:15 pm
I got 2 starlet engines freighted from perth to brissy for $200 through e-go.
Was all fine except they didnt send a tail life truck out to drop it off, luckily i had my engine crane so got them off the back of a truck that way. He wasnt happy, but cheered up a bit when i showed him a toyota engine in a mini.
Simplify and add lightness
PostPosted: Tue Jan 25, 2011 4:45 pm
Using E-Go, I recently freighted a short motor from Geelong to Adelaide for $35
Packing was in a cardboard box with craftwood fitted around each surface (6 pieces) with lots of torn up cardboard in the box as packing - engine wrapped in stacks of bubble wrap.
The weight was approx 65 kilos and it had to be on a small pallett so it could be fork lifted on or off the truck.
Rod Image
