https://ausmini.com/forums/
Is this worn suspension ??
https://ausmini.com/forums/viewtopic.php?f=2&t=68321
Author:  jethro [ Tue Jan 18, 2011 7:54 pm ]
Post subject:  Is this worn suspension ??
Hi Guys, before I put my 78 Leyland on axle stands, I measured the distance from the top of each tyre to the underside of the wheel arch and the readings were, 32mm,45mm,55mm and 52mm. Is this a worn suspension problem ?? I will be changing the front drums to discs eventually, so if I need to change something else I may as well do it at the same time. Any ideas would be a great help.
Jethro
Author:  GT mowog [ Tue Jan 18, 2011 8:10 pm ]
It maybe worn suspension, however it would more likely be worn body jiggs from when it was made!
