It is currently Sat Aug 09, 2025 4:44 am
 Post subject: guage help
PostPosted: Mon Jan 17, 2011 3:53 pm
Was after some help please. im getting no reading from my fuel gauge and temp guage. (in the clubman trple guage cluster)
and also my rev guage doesnt work for some reason dont know why
A nudge in the right direction would be much appreciated
1974 clubby with round nose conversion
1100 motor
extractors
twin 1 1/4" su's
lumpy cam (dunno what 1)
2 1/2" exaust
http://www.ausmini.com/forums/viewtopic ... sc&start=0
PostPosted: Mon Jan 17, 2011 3:57 pm
probably the old printed circuit behind its dead...i believe wombat(?) on here makes quite a good replacement...well that's my guess :lol:
PostPosted: Mon Jan 17, 2011 3:58 pm
but the spedo works
1100 motor
extractors
twin 1 1/4" su's
2 1/2" exaust
PostPosted: Mon Jan 17, 2011 3:59 pm
This space for rent
(SuX-855) wrote:
but the spedo works
The speedo is mechanical, the other gauges are not and depend on the printed circuit.
PostPosted: Mon Jan 17, 2011 4:46 pm
could be the voltage regulator - the I terminal feeds to the fuel and temperature guages. wombat makes electronic ones that are far more reliable than the old ones (and a hell of a lot cheaper!).
could be the printed circuit also - 40+years and they tend to be frail. "convertable mini" makes new ones on this forum.
PostPosted: Mon Jan 17, 2011 4:51 pm
try grounding out the wires (one at a time) that are connected to the fuel sender, if the guage goes to full when one of the (+) wires is connected to earth then its the sender.
If it doesnt make the fuel gauge go full for either wire (just the + should not both cables but just incase you have them reversed try both) then you possibly have one of the issues posted above above.
PostPosted: Mon Jan 17, 2011 5:09 pm
I'd place my bet on the printed circuit board, too. They are a little flimsy. But I reckon the big plug in the back might have just come loose.
Do your dash lights work?
 Post subject: Re: guage help
PostPosted: Mon Jan 17, 2011 6:16 pm
NAV-MAN
If this is a clubby there is usually a fuse on the firewall mixed in with the loom. Not the normal one on the inner wheel arch but on the firewall about 10-15cm away if you follow the loom inside the car.
PostPosted: Mon Jan 17, 2011 6:31 pm
ive never had guage lights ald ill have to have a look at those wires and the rear of the guages
1100 motor
extractors
twin 1 1/4" su's
2 1/2" exaust
PostPosted: Tue Jan 18, 2011 8:50 am
they both were working then they stopped working while driving the top fuse in the fuse box on the wheel arch is blown would that stop them working ?
1100 motor
extractors
twin 1 1/4" su's
2 1/2" exaust
