It is currently Sat Aug 09, 2025 5:24 pm
Post new topic Reply to topic  [ 46 posts ]  Go to page 1, 2, 3, 4  Next
 Post subject: Custom aircon condensors
PostPosted: Thu Jan 13, 2011 8:36 pm
Any idea where i could go???
PostPosted: Thu Jan 13, 2011 8:39 pm
Maybe ARE at Brendale?
They are specialist custom radiator and inter cooler guys, but might be useful.
http://www.are.com.au/
PostPosted: Thu Jan 13, 2011 8:44 pm
How custom? Where do want the thing or what's being done different to factory?
PostPosted: Thu Jan 13, 2011 8:54 pm
thanks Mick :D
it's funny my car was getting hot on the highway close to over heating..
aircon is not gassed up at the moment so not using it..
i decided to take it out the way from the grill to test if it was blocking air flow & the temp is not moving above halfway now!!! funny that..
it's a stupid design & blocks airflow.
i want to move it under the back of my car but the current one i have is a bit to thick & wont fit under the travalar unless i cut a square out of the rear subframe edging to slip it up there.
if it was a sedan it would fit no worries but the van has a big spare wheel hump underneath.
not sure if that would affect the strength etc.
i need something thinner like the later model aircon set ups or custom.
PostPosted: Thu Jan 13, 2011 9:07 pm
Stop pissfarting around with custom setups right there. :lol:
Go either the late setup or ditch it. A condenser under the back of the car sounds like a pain in the ass to assemble, service, get airflow too as well as be exposed to damage.
You may as well get a big one out of another car and install it like an intercooler on top of the engine with a scoop or outside the car under the bonnet!
PostPosted: Thu Jan 13, 2011 9:13 pm
haha i reckon it would work.. i mean they move the rads under the car up the back seems to cool the cars :)
same deal.
i can't see it not working?
PostPosted: Thu Jan 13, 2011 9:23 pm
I can't see it working at all.
The system wouldn't work very efficiently under there either, I mean the long run next to the exhaust might warm the gas up again!
PostPosted: Thu Jan 13, 2011 9:36 pm
good point but the engine bay is hot as well.
if you have the small late model alloy condensor you want to get rid of let me know..
otherwise i might have to buy a whole kit & i don't want to really.
PostPosted: Thu Jan 13, 2011 9:48 pm
$400 or $500 for a whole kit it a lot cheaper and easier than a custom setup.
Anything custom is a gold mine these days.
PostPosted: Fri Jan 14, 2011 4:42 am
Mods rock!
Adrad can do them, but you cannot deal direct. You can go through one of their authorised distributors, like Natrad.
PostPosted: Fri Jan 14, 2011 7:42 am
The last injected Japanese Minis with air con have the condenser bolted to the drivers side inner guard in basically the same position as the radiator on the passeneger's side. You could replicate that approach.
If your existing condenser won't fit in that position I'd be hitting the wreckers. The condenser from a small daihatsu, suzuki or similar should work.
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Sat Jan 15, 2011 11:38 am
This is what I was thinking of doing, mounting the condenser to the drivers side inner guard and replicate a whole in the guard for a electric fan sucking the air away from the condenser like late jap spec rover radiators do. Not much else is competing for space, or airflow once the hole and fan are there . And it's a lot better than mounting the condenser anywhere else in the car.
Lindsay Palmer
06 Mazda SP23
80 Alfa GTV (weekend toy)
86 626 Turbo (daily drive, now stolen)
71 cooper s replica
69 cooper replica
76 clubman
62 english 850
68 Mini Auto
PostPosted: Sat Jan 15, 2011 12:13 pm
it is the best spot indeed, i was trying not to cut the car for the moment i have pissed it off.
will think if i want to cut into the guard or not. :)
PostPosted: Sat Jan 15, 2011 12:38 pm
That's the only thing I have against the late Rover setups. It would be pretty hard to replace the cutout section if you ever wanted to restore the car to original.
I'd love a Traveller with late Rover SPi and Air Con. But I can't bring myself to cut and drill the Traveller that much. :(
Brett Nicholson
1966 Austin Mini
1973 LR Series 3 88
PostPosted: Sat Jan 15, 2011 12:42 pm
yes Bincho im in the same boat.
it's out for the moment it's just those sliding windows really keep that heat in.
