https://ausmini.com/forums/
Ignition Light
https://ausmini.com/forums/viewtopic.php?f=2&t=68278
Page 1 of 2
Author:  ryan [ Mon Jan 17, 2011 11:02 am ]
Post subject:  Ignition Light
Hi all.
I hopped in the car this morning and the ignition light is staying on. As I rev it, it get fainter but is still on. Now I checked the output voltage at the altenator and it reads 15.4V at idle. When I check the voltage at the battery at idle it is 12.5V.
I have been having trouble as the battery keeps draining on me.
What is wrong?
What can I check?
Author:  WiLo [ Mon Jan 17, 2011 11:41 am ]
you had this problem when we had the national park drive didnt you?
have you checked the earths?
possibly dud regulator?
Author:  ryan [ Mon Jan 17, 2011 11:44 am ]
The National park cruise was just a loose wire. I'm thinking dud reg too. Might take the alt out and take it over to the auto electricians.
Author:  ryan [ Mon Jan 17, 2011 11:45 am ]
It just seems weird that I have good voltage out at the alt but no where else.
I have check all the wires for continuity but they are all good.
Author:  GT mowog [ Mon Jan 17, 2011 11:54 am ]
Sounds like you could have an open circuit diode in your rectifer pack and with the battery draining, possibly another that is crook.
Author:  ryan [ Mon Jan 17, 2011 12:13 pm ]
the alt is out, just need to take it to the auto electrician to have a look see. Its times like these I wish I had a second car (well third car).
Author:  ryan [ Mon Jan 17, 2011 12:19 pm ]
Thanks GT,
Will let you know how I get on.
Author:  GT mowog [ Mon Jan 17, 2011 1:57 pm ]
Could one of your fellow 'Gong Mini members lend you an Alternator until you get yours sorted? Surely someone nearby has one lying about.
FYI, 1300 / 1600 Fort Escort & Cortina use the same Alternator (same mounts)
Author:  sgc [ Mon Jan 17, 2011 2:06 pm ]
That would be my guess too.. been down this road before ;)
Author:  GT mowog [ Mon Jan 17, 2011 2:16 pm ]
Just got me thinking.
Ryan, Have you got a decent soldering iron around 50 to 60 Watt?
My guess here is, rather than an actual failed diode, a poor or broken soldered joint.
Exactly what model alternator do you have?
Author:  WiLo [ Mon Jan 17, 2011 2:22 pm ]
[quote="GT mowog"]Could one of your fellow 'Gong Mini members lend you an Alternator until you get yours sorted? Surely someone nearby has one lying about. [\quote]
i have one but it was slowly dying when i took it out 9 months ago.
borrow the one of andys old motor?
Author:  ryan [ Mon Jan 17, 2011 2:30 pm ]
I don't really need the car. I have the gf's car tomorrow anyway to give it a service and take it for pinkslip. I just needed a car to get the alt to the auto sparky, so I rang my mum (good lady).
Should be ready tomorrow arvo I hope.
Author:  Irish Yobbo [ Mon Jan 17, 2011 2:33 pm ]
I'm actually a little concerned about your 15.4V out - that's a little high. It might damage the battery over time. So it could possibly be something with the regulator.
Author:  Morris 1100 [ Mon Jan 17, 2011 2:35 pm ]
It may also damage some electrical items.
Check the boot to see if the battery has been boiling and if it has clean it up!
Author:  ryan [ Mon Jan 17, 2011 2:37 pm ]
Yes, thanks for your concern. I too was worried about the high volts. The battery water was very low when I checked it this morning.
It should all be sorted by the auto electrician.
