Plastic Fuel Filter https://ausmini.com/forums/viewtopic.php?f=2&t=68262 |
Author: | Rocco [ Sun Jan 16, 2011 6:03 pm ] |
Post subject: | Plastic Fuel Filter |
Hi, My mini does not have a fuel filter installed, and I am looking at installing one. My concern is that i have a mechanical fuel pump and the pipe rises up near the exhaust manifold. I would assume that these filters are designed not to melt, though i am concerned with installing one with the manifold so close. Any suggestions or recommendations on which fuel filter i should install?? Thanks Rocco |
Author: | Mini_Maxx [ Sun Jan 16, 2011 6:08 pm ] |
Im running a plastic one ( was on the car when i got it), it sits up pretty high tho, mine has a straight fitting on the bottom ( inlet ) and a 90deg angled one on the top ( outlet). But its sitting a fair way away from the manifold |
Author: | GT mowog [ Sun Jan 16, 2011 6:12 pm ] |
The plastic Ryco ones were factory fitted from about 75 or so onwards. If you buy yourself about 300 mm of 1/4" fuel hose, you can so place the filter away from any hot bits. |
Author: | Mini_Maxx [ Sun Jan 16, 2011 6:17 pm ] |
GT mowog wrote: The plastic Ryco ones were factory fitted from about 75 or so onwards.
That explains how it got there then ![]() |
Author: | phillb [ Sun Jan 16, 2011 7:12 pm ] |
Mini_Maxx wrote: GT mowog wrote: The plastic Ryco ones were factory fitted from about 75 or so onwards. That explains how it got there then ![]() ![]() |
