It is currently Fri Aug 15, 2025 9:39 pm
 Post subject: Plastic Fuel Filter
PostPosted: Sun Jan 16, 2011 6:03 pm
Hi,
My mini does not have a fuel filter installed, and I am looking at installing one.
My concern is that i have a mechanical fuel pump and the pipe rises up near the exhaust manifold.
I would assume that these filters are designed not to melt, though i am concerned with installing one with the manifold so close.
Any suggestions or recommendations on which fuel filter i should install??
Thanks
Rocco
PostPosted: Sun Jan 16, 2011 6:08 pm
Im running a plastic one ( was on the car when i got it), it sits up pretty high tho, mine has a straight fitting on the bottom ( inlet ) and a 90deg angled one on the top ( outlet). But its sitting a fair way away from the manifold
Master of the Moggie Army & Founder of Awesomestock2010
PostPosted: Sun Jan 16, 2011 6:12 pm
The plastic Ryco ones were factory fitted from about 75 or so onwards. If you buy yourself about 300 mm of 1/4" fuel hose, you can so place the filter away from any hot bits.
PostPosted: Sun Jan 16, 2011 6:17 pm
That explains how it got there then :wink:
PostPosted: Sun Jan 16, 2011 7:12 pm
:lol:
Users browsing this forum: 1071 S and 445 guests
