It is currently Sun Aug 17, 2025 2:55 am
 Post subject: A+ Crank Pictures
PostPosted: Sat Jan 15, 2011 12:53 pm
Hi there,
I don't know if there is already pictures of A+ crankshafts but i thought some people might like to see close up of what the rolled radius looks like on the journals. This was done to stress relieve the transition area known to be a problem in earlier cranks as HP rose during Rover years.
This particular crank was out of mid 80's A+ Metro Turbo.
[IMG]http://i1143.photobucket.com/albums/n640/cometcosmo2003/IMG_0054.jpg[/IMG]
[IMG]http://i1143.photobucket.com/albums/n640/cometcosmo2003/IMG_0053.jpg[/IMG]
[IMG]http://i1143.photobucket.com/albums/n640/cometcosmo2003/IMG_0052.jpg[/IMG]
[IMG]http://i1143.photobucket.com/albums/n640/cometcosmo2003/IMG_0051.jpg[/IMG]
[IMG]http://i1143.photobucket.com/albums/n640/cometcosmo2003/IMG_0056.jpg[/IMG]
This crank has also been balanced, wedged and polished. The oil galleries have also been generously radiused for improved oil flow to the bearings.
Cheers :) :)
PostPosted: Sat Jan 15, 2011 1:10 pm
Forum only allows lowercase "img" it seems...
Jacob
PostPosted: Sat Jan 15, 2011 1:13 pm
Very nice, until a local grinder regrinds it...
BTW not all A+ cranks are like this.
PostPosted: Sat Jan 15, 2011 1:29 pm
Thanks Doc
This crank was ground by Action Crank's, Bob Lee.
Very happy to recommend Bob, he has decades of experience in motorsport, speedway,drags,V8s, also minis.
I did the cleanup and polishing and GR did the wedge and balance.
Cheers :)
PostPosted: Sat Jan 15, 2011 1:50 pm
Great photo's Cometcosmo2003,
That rolled radius does make a huge difference to the strength of the crank. Anything with a step, or sharp conner or edge is a potential weak spot (a place for it to start cracking from).. by putting a decent radius in there it makes it infinitely stronger.
If you look at all the modern perfomance Jap stuff, thier cranks will have a similar radius.
PostPosted: Sat Jan 15, 2011 2:14 pm
I agree PK. Very nice looking crank.
However if you're going to stroke a crank by offset grinding, the rolled fillet one is not I would use to begin with, as the rolled fillet will 3/4 disappear when the crankpins are offset ground.
