It is currently Mon Jul 21, 2025 10:14 pm
PostPosted: Fri Jan 14, 2011 7:56 pm
Cooper 'S'
Type; YKG2S2
Car number; 1686
Engine number; 9F/Say/ 40690
or
Cooper 'S'
YKG2S2
Car Number; 935
Engine Number; 9FSay/38760
If you know who now owns either of the cars with these IDs please let me know.
Thanks
Ty
PostPosted: Wed Mar 22, 2017 6:35 pm
TK wrote:
Cooper 'S'
Type; YKG2S2
Car number; 1686
or
Cooper 'S'
YKG2S2
Car Number; 935
Thanks
Ty
Looking for this? https://www.gumtree.com.au/s-ad/yatala/ ... 1142742361
PostPosted: Wed Mar 22, 2017 9:02 pm
Another bloody 'S' barstardised. Some colour green they probably think is BRG. Can't even get the front panel correct.
PostPosted: Wed Mar 22, 2017 9:19 pm
Looks like they had the front panel correct then changed it back.
PostPosted: Wed Mar 22, 2017 10:03 pm
That body is not the one that matches that ID plate.
PostPosted: Thu Mar 23, 2017 8:27 pm
As a novice here "please explain"
Phil
PostPosted: Thu Mar 23, 2017 9:52 pm
Simple. That ID plate doesn't belong to that body.
PostPosted: Thu Mar 23, 2017 10:17 pm
looks blue on the back section
PostPosted: Fri Mar 24, 2017 8:42 am
That might be a diversion
PostPosted: Fri Mar 24, 2017 8:45 am
For the last time, THAT ID PLATE DOES NOT MATCH THAT BODY.
PostPosted: Fri Mar 24, 2017 9:42 am
Tk.. how are you so confident to say that? Just by looking at the pics
PostPosted: Fri Mar 24, 2017 10:35 am
Have you seen the chassis number stamping on the radiator cowling?
PostPosted: Fri Mar 24, 2017 10:56 am
He used to own the car. Maybe he remembers what the body looked like.
The photos make it hard to work out if it is a deluxe or an S. If its the original body then has the wrong front panel for car 1686. The early front panels where changed over around 300 cars prior.
PostPosted: Fri Mar 24, 2017 12:28 pm
FFS. I sold the ID plate 20 years ago. I know where the matching shell is. Good enough?
PostPosted: Fri Mar 24, 2017 12:32 pm
That explains why it has fresh cold gal paint over the stampings. Must be welded and restamped. Thanks for the info TK. I will add it to my replica database.
