It is currently Tue Aug 19, 2025 6:15 am
 Post subject: 12 inch rims
PostPosted: Wed Jan 12, 2011 11:34 pm
Hey guys im running 12 inch rims and i was wondering if i could get smaller series tread i got 60 at the moment but i want something like 50 ??? can u get it ???????????? the height of the rubber that is
PostPosted: Thu Jan 13, 2011 7:56 am
My Dunlop D01J's are 165/55/R12. But they are NLA I believe.
PostPosted: Thu Jan 13, 2011 9:07 am
Remember, the second number in a tyre size is not the wall height as a measurement, its the height as a percentage of the tyres width.
for example: 145/70 r12: tyre wall is 70% of 145 = 101.5mm
165/60 r12: tyre wall is 60% of 165 = 99mm
175/50 r13: 50% of 175 = 87.5mm
So there you have it, three different tyre sizes, all within 2mm diameter of each other.
:D
PostPosted: Thu Jan 13, 2011 9:39 am
yokohama's 12" semi slicks (A048R) are 55 series profile (165/55R12).
Why do you want lower profile? just for looks or are you trying to reduce the rolling diameter?
If its for looks 13" tyres have a lower profile. Maybe worth considering changing to 13" wheels if you like the look. :wink:
-James.
Toyota 4EFTE Powered Minivan.
PostPosted: Thu Jan 13, 2011 9:51 pm
for looks :)
PostPosted: Thu Jan 13, 2011 11:13 pm
NAV-MAN
i got a mini wrote:
for looks :)
MMMMmmmm looks :D
PostPosted: Thu Jan 13, 2011 11:23 pm
They're really nice mags Nav.. Image
*edit* Oops...... I blame the drugs..... Sorry Nav.
PostPosted: Thu Jan 13, 2011 11:32 pm
MiniKit wrote:
They're really nice mags NAV.. Image
Fixed :D
MINE:
1976 Clubby 1100, 266 Kent cam, slightly worked head. (awaiting paint)
1978 1275LS Hi-Ho Silver with a Camtech 619 cam and some strange looking rockers
PostPosted: Fri Jan 14, 2011 10:19 am
i got a mini wrote:
for looks :)
Get 13's then. :D
-James.
PostPosted: Fri Jan 14, 2011 10:22 am
Need to go guard chopping if you go 13's though...
PostPosted: Fri Jan 14, 2011 1:21 pm
Not if they have enough positive offset.
:D
PostPosted: Fri Jan 14, 2011 1:59 pm
Or u wind the castor right back 8)
IS NOW BACK ONLINE AFTER SOMETIME..... SORRY TO ALL, FOR NOT REPLYING TO PM'S!!
PostPosted: Fri Jan 14, 2011 6:34 pm
NAV-MAN
Some very interesting handling to be had right there. I wonder what it would do??
PostPosted: Fri Jan 14, 2011 7:48 pm
Prevent the steering wheel from self centering.
PostPosted: Fri Jan 14, 2011 8:43 pm
Also will understeer to buggery on tight turns.... not a good look.
