Coolant Type https://ausmini.com/forums/viewtopic.php?f=2&t=67985 |
Page 1 of 3 |
Author: | IndigoBlueCooperS [ Sun Jan 02, 2011 2:26 pm ] |
Post subject: | Coolant Type |
What is the best option for coolant in a Mini used in warmer (and non-freezing) conditions? I understand the ethylene glycol used in some coolants reduces the heat transfer rate, thus reducing its efficiency to cool the engine. The upside of the ethylene glycol is that it increases the boiling point a bit, but hopefuuly we don’t get that hot. Any recommendations? |
Author: | drmini in aust [ Sun Jan 02, 2011 2:33 pm ] |
I use Nulon ethylene glycol (25%) in my 1412 and 1360 motors, neither has ever overheated. Radiator is a stock 1970 Oz one (16 fins/inch) and a MiniMatic heater. [edit] rad cap is 82°C |
Author: | 74snail [ Sun Jan 02, 2011 3:49 pm ] |
Now that my radiator cap actually fits ( the most ignored part of the process when looking at overheating !!! ) , I,m using 30 % Rust Inhibitive , 20 % Coolant and 50% water , my system is stable , no problems , the only time its got past halfway on the gauge was a warm day stuck in traffic 13 pound cap 82deg thermostat . |
Author: | GT mowog [ Sun Jan 02, 2011 4:33 pm ] |
If your running one of those (aweful) alloy radiators, the choice of coolant is critical. If your running the stock copper job, then most coolants will be quite OK. |
Author: | Mick [ Sun Jan 02, 2011 4:44 pm ] |
A while back I had a brain fart as I mixed poured my castrol glycol concentrate into my radiator. I was aiming for a 50:50 ratio of glycol and water, but poured in 2.5 litres of glycol instead of 1.5. This meant that less than a litre of water went in, and the ratio was up around 5:6. I drove it for a couple of weeks before I put it back to rights (I was pressed for time during uni, and had to come up with a clean solution to retrieve the wasted glycol). I have some very accurate digital gauges installed in my car and I was able to see the difference straight away. I found that yes, the car ran hotter, but not by much. About 2-3 degrees was the maximum change. There were hot days in there as well, but the temperature remained stable at the slight increase. It wasn't anything to get concerned over I suppose, but it's not worth wasting the expensive glycol anyway. |
Author: | Convertible Mini [ Mon Jan 03, 2011 8:50 am ] |
Post subject: | Best Coolant |
The best one I have found is the one sold by Toyota. It is red and does not EAT at any alloys when it meets with Air. Most others I stay way from regardless their "pretty colours". They act like an accumulator from the tests we have done. You get what you pay for. |
Author: | woodwormm [ Mon Jan 03, 2011 6:47 pm ] |
Post subject: | Re: Best Coolant |
Convertible Mini wrote: The best one I have found is the one sold by Toyota. It is red and does not EAT at any alloys when it meets with Air. Most others I stay way from regardless their "pretty colours". They act like an accumulator from the tests we have done. You get what you pay for.
make sure you get the concentrated one from Toyota, the one you mix 50/50 with demin water... their new premix is a ripoff and not as good ![]() |
Author: | Mick [ Mon Jan 03, 2011 6:55 pm ] |
What is the dosh for the Toyota stuff anyway? Its a little less than 15 dollars per litre for the Castrol coolant. |
Author: | superSeven [ Mon Jan 03, 2011 7:07 pm ] |
GT mowog wrote: If your running one of those (aweful) alloy radiators, the choice of coolant is critical. If your running the stock copper job, then most coolants will be quite OK.
you like them that much you are in awe of them? ![]() |
Author: | GT mowog [ Mon Jan 03, 2011 7:09 pm ] |
Mick wrote: ................ Castrol coolant. I had this in an engine that was stored for just on 28 years. I was expecting the absolute worst when I pulled the drain plug on the block, but was very pleasantly surprised when it came out green and on pulling the welsh plugs the block was still grey inside - no rust at all! |
Author: | GT mowog [ Mon Jan 03, 2011 7:15 pm ] |
superSeven wrote: GT mowog wrote: If your running one of those (aweful) alloy radiators, the choice of coolant is critical. If your running the stock copper job, then most coolants will be quite OK. you like them that much you are in awe of them? ![]() Yeah, it really Awes me every time I see them split, crack and corrode to the point of choking! That is really one of them 'Awe-shit, again!' moments...... |
Author: | Morris 1100 [ Mon Jan 03, 2011 7:17 pm ] |
GT mowog wrote: superSeven wrote: GT mowog wrote: If your running one of those (aweful) alloy radiators, the choice of coolant is critical. If your running the stock copper job, then most coolants will be quite OK. you like them that much you are in awe of them? ![]() Yeah, it really Awes me every time I see them split, crack and corrode to the point of choking! That is really one of them 'Awe-shit, again!' moments...... I hate the way that the little radiator places are all closing due to the cheap Chinese imports. ![]() |
Author: | GT mowog [ Mon Jan 03, 2011 7:21 pm ] |
Morris 1100 wrote: GT mowog wrote: superSeven wrote: GT mowog wrote: If your running one of those (aweful) alloy radiators, the choice of coolant is critical. If your running the stock copper job, then most coolants will be quite OK. you like them that much you are in awe of them? ![]() Yeah, it really Awes me every time I see them split, crack and corrode to the point of choking! That is really one of them 'Awe-shit, again!' moments...... I hate the way that the little radiator places are all closing due to the cheap Chinese imports. ![]() Out of curiosity, how old is the copper one in your Morris 1100? |
Author: | Morris 1100 [ Mon Jan 03, 2011 7:26 pm ] |
GT mowog wrote: Morris 1100 wrote: GT mowog wrote: superSeven wrote: GT mowog wrote: If your running one of those (aweful) alloy radiators, the choice of coolant is critical. If your running the stock copper job, then most coolants will be quite OK. you like them that much you are in awe of them? ![]() Yeah, it really Awes me every time I see them split, crack and corrode to the point of choking! That is really one of them 'Awe-shit, again!' moments...... I hate the way that the little radiator places are all closing due to the cheap Chinese imports. ![]() Out of curiosity, how old is the copper one in your Morris 1100? 44 years old. I have not touched it in the 12 years I have owned the car. I don't know if it has ever been out. It looks like the original core. |
Author: | GT mowog [ Mon Jan 03, 2011 7:28 pm ] |
Morris 1100 wrote: GT mowog wrote: Out of curiosity, how old is the copper one in your Morris 1100? 44 years old. I have not touched it in the 12 years I have owned the car. I don't know if it has ever been out. It looks like the original core. Hmmmm....I'd like to see one of those chinalloy radiators go 4.4 years....... Even BL learnt the hard way. The first Metros had alloy radiators, they soon went back to copper....... |
Page 1 of 3 | All times are UTC + 10 hours |
