Handbrake Warning Light and switch https://ausmini.com/forums/viewtopic.php?f=2&t=66726 |
Author: | Super-mini [ Wed Nov 03, 2010 7:41 pm ] |
Post subject: | Handbrake Warning Light and switch |
read a few old posts but didnt find the info i was looking for, I need to install one on my rover mini to pass compliance, and i was wondering what other people have in their rover minis, or even the 77,78 leylands. what i have already is the little light that sits in the top crash panel out of a 77 mini s wreck, but someone already pilfered the switch so i dont know what i'm looking for. pics would be greatly appreciated, thanks! |
Author: | Morris 1100 [ Wed Nov 03, 2010 7:45 pm ] |
I don't have one that I can take a picture of straight away but it is just like a door light switch with a little bracket to hold it under the edge of the handbrake lever. |
Author: | VicMini13 [ Thu Nov 04, 2010 7:19 am ] |
Morris 1100 wrote: I don't have one that I can take a picture of straight away but it is just like a door light switch with a little bracket to hold it under the edge of the handbrake lever.
.... and you wire it by picking up a switched and fused active wire to one side of the globe, and the other side of the globe goes to the switch which earths it to the body when closed. |
Author: | winabbey [ Thu Nov 04, 2010 11:49 am ] |
This is the switch installed as part of SPO41 (Police specification MK II S). The switch is a Linread, same as a Mini roundnose door switch and the holder and tab are fabricated. ![]() |
Author: | GT mowog [ Sat Nov 06, 2010 4:55 pm ] |
The 1275 LS was the same as this set up (from a 1978 Clubbie S) ![]() |
Author: | Super-mini [ Sat Nov 06, 2010 6:02 pm ] |
thanks everyone that helps alot |
Author: | TUCK3r [ Sun Jul 22, 2012 8:45 pm ] |
My handbrake light stopped working im not getting power at the light . Is there ment to be power going to the switch? Were does it pick up power from? Cheers Dan |
Author: | michaelb [ Sun Jul 22, 2012 8:56 pm ] |
No power to the switch. One side is earth from the body connection and the main wire/lead goes to the lamp and the other side of the lamp then goes to power via a fuse. Maybe your globe is blown? |
Author: | TUCK3r [ Sun Jul 22, 2012 9:00 pm ] |
Im not sure was working up untill handbrake braket broke. Ive checked power and earthed the switch im getting nothing. Should the fuse be in engine bay or in the wiring behind the gauges? |
Author: | cooperess [ Sat Aug 04, 2018 5:12 pm ] |
Post subject: | Re: |
winabbey wrote: This is the switch installed as part of SPO41 (Police specification MK II S). The switch is a Linread, same as a Mini roundnose door switch and the holder and tab are fabricated. ![]() Is this switch used on any other Mini models and is there a part number. |
Author: | Bill B [ Sat Aug 04, 2018 7:57 pm ] |
TUCK3r wrote: My handbrake light stopped working im not getting power at the light . Is there ment to be power going to the switch? Were does it pick up power from? Cheers Dan I'm not sure if you are talking about a roundnose mini or later. For police spec. roundnose switches like winabbey has shown, the power is picked up from the voltage stabiliser/regulator unit mounted on the speedo housing at B (battery) terminal, then to the warning light and earths at the Linread switch to body. |
Author: | cooperess [ Sat Aug 04, 2018 9:20 pm ] |
Post subject: | Re: Handbrake Warning Light and switch |
The handbrake switch would be a good interior door light switch replacement. So if there is a part number I could research it. |
Author: | Scoop [ Sat Aug 04, 2018 9:42 pm ] |
https://minikingdomonline.com.au/produc ... ht-switch/ |
