Turbo Pistons https://ausmini.com/forums/viewtopic.php?f=2&t=630 |
Page 1 of 2 |
Author: | MiniK [ Wed May 19, 2004 3:17 pm ] |
Post subject: | Turbo Pistons |
Ive asked this before on the old Ausmini but thought id ask it again, seeing as more people frequent here now. Does anyone know where dished pistons can be sourced? I think most of the poms are using cast Hepolite's with a 10cc dish( which i think are standard on the metros). Anyhow any help will be greatly appreciated ![]() |
Author: | drmini in aust [ Wed May 19, 2004 5:19 pm ] |
You can buy Hepolite 21250s from MiniSpares. They are 9.4:1. Bit high, I reckon, if you are adding a serious amount of boost. But you can hack the chambers out in the head... ![]() Whatever, DON'T use 21251s. They are too weak for this application.. ![]() |
Author: | MiniK [ Thu May 20, 2004 8:46 am ] |
Crikey...yeha 9.4:1 is a tad high...... i think im going to have a proper look around...... ![]() |
Author: | turbomini [ Thu May 20, 2004 3:42 pm ] |
you could use the 9.75:1 standard hypertec or hepolite pistions... but u could only run SFA boost like 5 pound.. (on regular 98 fuel that is) or just find some stocker pistions 8.8:1 i used them for quite a while as long as its not pinging theres no problems.. my cars still running with them.. no problems yet |
Author: | kazjim [ Thu May 20, 2004 7:02 pm ] |
Mine's a 998, and I run the AE (Hepolite) 20773's (all 3 compression rings ON !) Running 14+Psi regularly.. no reliability probs yet! J |
Author: | drmini in aust [ Thu May 20, 2004 7:18 pm ] |
21251s (8.8:1) will work, but they are a bit weak for lots of boost and high rpm. There's not a lot holding the crown on- as the oil drain slots are huge. Yes they are cheap.... I've got a set in my wife's 1293A+, but it ain't getting revved hard or boosted.. ![]() |
Author: | MiniK [ Wed May 26, 2004 11:49 am ] |
drmini in aust wrote: 21251s (8.8:1) will work, but they are a bit weak for lots of boost and high rpm. There's not a lot holding the crown on- as the oil drain slots are huge. Yes they are cheap....
I've got a set in my wife's 1293A+, but it ain't getting revved hard or boosted.. ![]() any idea what amounts of boost these things would hold though? |
Author: | drmini in aust [ Wed May 26, 2004 5:37 pm ] |
No idea whatever. They are a cheap low compression road piston and not designed for turbo use... You blow it, you risk it.. ![]() I'd get some Hypertecs, grind the head chambers out if you have to. |
Author: | MiniK [ Wed May 26, 2004 6:09 pm ] |
drmini in aust wrote: No idea whatever. They are a cheap low compression road piston and not designed for turbo use... You blow it, you risk it..
![]() I'd get some Hypertecs, grind the head chambers out if you have to. Hypertecs? Where do i find them? The standard metro items would be ok wouldnt they if i could find them...there part no. is 20831. |
Author: | drmini in aust [ Wed May 26, 2004 7:36 pm ] |
Dunno that number. Hepolite 21250 is a 9.4:1 piston made for Metro turbo. Thicker crown etc than 21251... Just open out the chambers... stock is 21.4, mine are 28.0cc, you can get them made even bigger. ![]() |
Author: | MiniK [ Thu May 27, 2004 3:02 pm ] |
well karcraft said that Hepolite dont make the 20831's anymore:( i might have to look into those 21250's then.... Kev do you have any idea what the comp ratio would work out to be using those pistons, with a chamber say 28cc's in size or larger, and 20" overbore? |
Author: | minitec [ Thu May 27, 2004 3:28 pm ] |
dave, all I can say is what James had as a sig on Minimania..... vvvvvvvvvvvvvvvvvtttttttttttttt psssssssssshhhhhhhhhhhh........ vvvvvvvvvvvvvvvvvtttttttttttttt psssssssssshhhhhhhhhhhh.......... vvvvvvvvvvvvvvvvvtttttttttttttt psssssssssshhhhhhhhhhhh......... |
Author: | MiniK [ Thu May 27, 2004 5:01 pm ] |
minitec wrote: dave, all I can say is what James had as a sig on Minimania.....
vvvvvvvvvvvvvvvvvtttttttttttttt psssssssssshhhhhhhhhhhh........ vvvvvvvvvvvvvvvvvtttttttttttttt psssssssssshhhhhhhhhhhh.......... vvvvvvvvvvvvvvvvvtttttttttttttt psssssssssshhhhhhhhhhhh......... ![]() |
Author: | MiniK [ Thu May 27, 2004 9:13 pm ] |
Got a qoute from MED in the UK for 210 pds for a set of dished omega pistons 20" over.......plus 40 pounds shipping...... So about $680....... Naturally if theres a cheaper option i wouldnt mind taking it ![]() |
Author: | kazjim [ Thu May 27, 2004 9:22 pm ] |
And Everyone still wonders why i did a 998 ? sheesh, for the money you spend on a set of pistons, i could build a whole engine !!! only 300cc's less ..... just wind another 7Psi into it, and you've increased the "theoretical" displacement another 50% ! (so a 998, at 14psi has the torque of a 1500cc !!) - something like that anyway........ J |
