Master Cylinders https://ausmini.com/forums/viewtopic.php?f=2&t=586 |
Author: | ronniemac [ Wed May 12, 2004 10:40 pm ] |
Post subject: | Master Cylinders |
Apart from the position of the tank to the cylinder is there any differance between the brake and the clutch master cylinders, as in the volume each pumps ? I wouldn't have thought so as both seem to have the same bore but i want to make sure. |
Author: | drmini in aust [ Wed May 12, 2004 10:45 pm ] |
Clutch master cylinders are all 0.750" bore (or should be...) Brake masters varied- original 850 was 0.750", late 998 Cooper was 0.625", all others were 0.700". Many Clubbies had tandem (dual circuit) ones. Brake masters all have a restrictor valve in the top, clutch ones do not. ![]() <edit> brake MC sizes above do not apply to late UK imports- I know f'all about them. ![]() |
Author: | Hanra [ Thu May 13, 2004 6:24 pm ] |
In the master cylinders with the metal body plastic tank both the bore sizes are the same, they are exactly the same unit except that the brake master cylinder has a non return valve and the clutch one doesnt. Not to sure about the tin tank master cylinders though? |
Author: | drmini in aust [ Thu May 13, 2004 7:05 pm ] |
The new plastic tank type replacement brake cylinders are 0.700" bore. p/no is GMC171. Clutch one with plastic tank is 0.750" bore, p/no is GMC1008. They are not the same but do look it... ![]() |
Author: | Hanra [ Thu May 13, 2004 8:48 pm ] |
Extract from Gregorys Workshop Manual Pg 131 states, The brake and clutch master cylinders are identical, except that the clutch master cylinder has no non-return valve. Who is right?? |
Author: | drmini in aust [ Thu May 13, 2004 8:56 pm ] |
They were right back when the 850 was all you could buy.... But, since 1965, (when twin leading shoe front brakes were fitted) all Oz Minis have had a 0.700 bore master cylinder, not 0.750. This includes Deluxe, Cooper S, Mini K, etc. late Clubbie brake MCs were tandem, but still 0.700" bore. Source- Leyland Australia's factory MINI workshop manual (the last one produced here, 1976- still available from Pitstop Bookshop) My part numbers for the NEW cylinders are from Karcraft's current catalog. |
Author: | ronniemac [ Thu May 13, 2004 9:02 pm ] |
Thanks guys. I think all that info has helped ? |
