https://ausmini.com/forums/
gear selector and rocker asjustment
https://ausmini.com/forums/viewtopic.php?f=2&t=56204
Author:  Leighton [ Wed Aug 19, 2009 6:18 pm ]
Post subject:  gear selector and rocker asjustment
ive just put the engine into the mini (rod change) but im having difficulty finding 1st and 2nd, i can get the other three quite easily.
the gearbox was rebuilt by a reputable mini specialist, i cant think of any reasons why its playing up, anybody got some ideas?
i was also reading the manual with rocker adjustments and it says to put the car in gear and move it back and forward, but its very difficult to move the car in 4th? do i need to apply a bit more force?
thanks for any help,
cheers Leighton
Author:  mini_mad_matt [ Wed Aug 19, 2009 6:36 pm ]
To do your rockers, take your spark plugs out, and if the car is on a flat you should be able to rock it by yourself. It will take a bit of a shove but nothing you shouldnt be able to manage. It's still possible with spark plugs in, just harder due to compression.
Author:  WiLo [ Wed Aug 19, 2009 6:54 pm ]
leighton is it still a rod change gearbox?
in 4th it shouldnt be too hard to move back and forward.
Author:  Leighton [ Wed Aug 19, 2009 7:03 pm ]
yer its still rod change, i think maybe because its all new, im holding back a bit too much. also i still have to put the engine stabilisers on because the engines flopping about like all hell.
Author:  simon k [ Wed Aug 19, 2009 7:09 pm ]
you'll never get a good selection unless you've got the engine steadies done up - the rods will be moving the motor around
also makes it that much harder to do the rockers...
Author:  NAV [ Wed Aug 19, 2009 7:15 pm ]
Post subject:  Re: gear selector and rocker asjustment
cheers Leighton
Can you just puill across for reverse and not have to lift the gearstick? if so my money is the plate at the bottom underneath the selector being in the wrong way, instead of locking you out of reverse its stopping you from geting 1st/2nd. The lockout tab should be on the left side when it's sitting in the car properly.
Author:  minimanic [ Wed Aug 19, 2009 7:49 pm ]
With adjusting the rockers, I've always just got a short wire with a spade terminal on one end, bare wire on the other. Plug it onto the solinoid at the crank terminal, and jump it over to the battery terminal on the solinoid to turn the motor over to where you want it.
Make sure ignition is off and gearbox in neutral first!
Short 'taps' of the wire work best.
If you wind it over a little far, turn it back with the fan.
I've done it this way countless times, works a treat :D
Author:  WiLo [ Wed Aug 19, 2009 8:20 pm ]
if im out and about on saturday i might come past that way and see if i can be of any assitance(although not likely)
Author:  gafmo [ Wed Aug 19, 2009 9:15 pm ]
male and Femal toggles on the back of the motor are a spline or two out
I also use the rocking method with the spark plugs out but sometimes its a good idea to have a couple of bricks waiting a bit further back but on a flat would be highly recomended
Author:  Leighton [ Wed Aug 19, 2009 10:36 pm ]
NAV how much money did you put on your bet... if so you could be a rich man :wink:
ill probably adjust the rockers tommorow.
wilo come by if you want... the mini needs to be completed by monday ready for marking :shock:
Author:  simon k [ Thu Aug 20, 2009 10:49 am ]
gafmo gafmo gafmo..... you've gotta read the posts dude!!
Author:  NAV [ Thu Aug 20, 2009 1:28 pm ]
Lol. I did it to myself when i first cleaned out the old grease and packed it with new grease. I sat there for ages tryinng to figure it out and then my mate (who owns minis as well) said did you put the plate back in the same way. :oops: :roll: 8)
Author:  mini-dunger [ Sun Nov 02, 2014 7:29 pm ]
Hey mate did you figure out why you could not get 1st and 2nd?
