What did you do on your Mini today? https://ausmini.com/forums/viewtopic.php?f=2&t=52415 |
Page 1 of 568 |
Author: | willy [ Wed Apr 22, 2009 11:06 pm ] |
Post subject: | What did you do on your Mini today? |
Hopefully this will continue onto being a long-running thread. Stolen from another forum. Pics are ok - limit them to one or two if you can, and keep them at a usable forum size (800x600). SO.... What did you do on your Mini today? Today I bought some new fuel line, new Facet competition fuel pump, and did a small rust replacement on the rear floor (panel that the rear seat cushion sits on). |
Author: | BALLISTIC [ Wed Apr 22, 2009 11:15 pm ] |
Nothing on mine........but I made 1 blokes run, stop and steer much, much better! ![]() ![]() |
Author: | doogie [ Wed Apr 22, 2009 11:16 pm ] |
Graham Russell milled one of his manifolds for me, as im having trouble fitting my HIF44 carb & manifold into my MK2 Cooper S, after getting it milled i refitted it to the car, still no luck, manifold won't seal onto the manifold gasket. Looks like it gunna have to trim some metal out of the firewall ![]() Doogie |
Author: | superSeven [ Wed Apr 22, 2009 11:19 pm ] |
bought a new water pump.. cast impellor! ![]() |
Author: | red_850 [ Wed Apr 22, 2009 11:26 pm ] |
I reamed out my trailing arm bushes. |
Author: | DTrain [ Wed Apr 22, 2009 11:40 pm ] |
havent done anything since the last holidays, and wont be doing anything till the next one. ie june ![]() |
Author: | d1ck0 [ Wed Apr 22, 2009 11:52 pm ] |
I thought about what I need to do to get in going for the Cruise to the Qld Mini Muster. Does that count? Dicko |
Author: | justfanginaround [ Wed Apr 22, 2009 11:54 pm ] |
flogged the crap out of mine coz the new motor is about to be finished |
Author: | AEG163job [ Thu Apr 23, 2009 12:29 am ] |
severely reduced the power-to-weight ratio of my Moke- refitted the sump guard......... in readiness for a Deua National Park adventure. ![]() |
Author: | brett [ Thu Apr 23, 2009 12:42 am ] |
had a new alarm system fitted take that Theives |
Author: | MiniMan_Alis [ Thu Apr 23, 2009 7:23 am ] |
i brought parts from the mini king!!!! with the stimulus package ![]() |
Author: | miniDave [ Thu Apr 23, 2009 7:32 am ] |
- Removed front hubs and greased the bearings - Painted and replaced the brake backing plates - Installed new twin wheel cylinders on each side - Re-shimed the top and bottom ball joints on both sides - Drilled out a broken grease nipple, re-threaded and replace nipple in hub - Connected new brake hoses on both sides on the front - Replaced new brake line that runs around front of the front subframe - Bolted new engine mounts to engine (ready to put in) |
Author: | i got a mini [ Thu Apr 23, 2009 7:36 am ] |
bout to pull out my radiator casue it is no good ![]() |
Author: | matt van'74 [ Thu Apr 23, 2009 7:50 am ] |
I chased some electrical faults and cleaned up the wiring a bit in spots. Then took it for a drive. Matt |
Author: | gafmo [ Thu Apr 23, 2009 7:57 am ] |
Yesturday I back to Blinging the 48 Dellorto ![]() ![]() |
Page 1 of 568 | All times are UTC + 10 hours |
