It is currently Fri Aug 01, 2025 5:52 pm
PostPosted: Fri Jan 30, 2009 9:56 am
my brother and i pulled my engine down and could someone tell me what the name of this bearing is called as it needs replacing....first picture ia where it is located and second is the bearing
PostPosted: Fri Jan 30, 2009 10:06 am
That would be:
http://www.minisport.com.au/prod448.htm
Andrew@Minisport, South Australia
Ph: 08-8177-1275
Skype: minisport.au
Minisport for all your mini parts
PostPosted: Fri Jan 30, 2009 10:12 am
out rigger
PostPosted: Fri Jan 30, 2009 10:23 am
thankyou
PostPosted: Fri Jan 30, 2009 12:38 pm
you'll need to remove the outer race from the housing - put a bolt through a large washer and weld it in place, weld the washer to the outer race, then put something big over the top, and screw a nut onto the bolt to pull it out
if you know what I mean...
PostPosted: Fri Jan 30, 2009 12:45 pm
two big screw drivers to lever it up a little, then a bearing puller to take it the rest of the way. Simple. :wink:
PostPosted: Fri Jan 30, 2009 4:49 pm
Heat the cover with the oxy and drop the cover face down on concrete. [/butcher mode]
PostPosted: Sat Jan 31, 2009 1:26 am
:idea: first pull out the circlip that holds the outter bearing race in or you will be there for a while :!: :lol: 8)
As morris said but ut may take more than on drop or hit on the ground.
 Post subject: Again
PostPosted: Sat Jan 31, 2009 1:07 pm
The outer bearing cone can also be removed easily by running a weld on the inner face with an arc welder which causes it to shrink and it will fallout easy.
"Let us remove your "SHORTS"
PostPosted: Sat Jan 31, 2009 1:14 pm
I am amazed with the forum lately , 6 months ago the same question would have returned a dozen posts saying "it's called rooted" or similar . Well done to everyone who's given good , clear advice .
