https://ausmini.com/forums/
window seals
https://ausmini.com/forums/viewtopic.php?f=2&t=49760
Author:  redrocketrider [ Fri Jan 30, 2009 9:28 pm ]
Post subject:  window seals
guys I need help
,I need the outer window strips for my door,
too stop the water getting in,
do they come in a kit?
what exactly do I need
Author:  Mick [ Fri Jan 30, 2009 9:38 pm ]
What's your doors? Windup or sliding window? And which seals do you mean? The one around the door frame the to seal the door against the car, or the ones around the window?
Author:  850man [ Fri Jan 30, 2009 9:41 pm ]
They are available and are easy to get from all the mini shops and automotive rubber suppliers such as "scotts old auto rubbers" here in melbourne. New clips are also available. The factory part no. for the seal is HYA2790 and 34G939 for the clips, you will need 4 clips per seal.
Author:  redrocketrider [ Fri Jan 30, 2009 9:42 pm ]
windup,
ones on the outside of the window between the window and outer door
Author:  drmini in aust [ Fri Jan 30, 2009 9:44 pm ]
Those are called weatherstrips.
I bought MGB ones from Heritage MG and cut them to length. They are same cross section as originals and fit in the clips better than the locally made stuff. :wink:
Author:  850man [ Fri Jan 30, 2009 9:44 pm ]
PS, by the sound of your question i think you want the seals for the wind up window doors, the sliding window door channels are also available from the same suppliers.
Author:  redrocketrider [ Fri Jan 30, 2009 9:46 pm ]
do they come as one piece?
or are there serveral parts someone told me there is a chrome strip too
Author:  Mick [ Fri Jan 30, 2009 10:05 pm ]
Use the stainless steel strip which is already on your car, the weatherstrip sits clipped onto those chrome strips by the same clips that hold the steel strip onto the door.
Author:  drmini in aust [ Sat Jan 31, 2009 8:14 am ]
Be very careful taking those chrome strips off, if you get heavy with a flat blade screwdriver you will dent them, (inner ones in particular) they are prone to bending too.
If the clips on the door have had it, get new ones. I think Mini King has them.
