It is currently Mon Jun 23, 2025 4:30 am
PostPosted: Mon May 03, 2004 12:29 pm
hey all,
just wondering where abouts to find these:
**(engine/VIN/Chassis numbers)**
on a '72 clubby.
i have the rego sticker, will it say on that too??
thanks heaps guys
John
PostPosted: Mon May 03, 2004 12:41 pm
A 72 model would be either on the left inner guard on the compliance plate or body number stamped on the bulkhead behind the master cylinders. Engine number is stamped on the block behind the alternator. It will be written on the rego sticker but it is good to check anyway.
Anto.
PostPosted: Mon May 03, 2004 12:52 pm
Clubbies should all have a VIN plate on the drivers side inner guard (top).
There is also this same number (including body type prefix) stamped into the top of the radiator shroud. (early roundnose cars this was not the body #, but from 1970 on, including Clubbies it is)
Good luck- they are often defaced/missing... :wink:
