Drum Brakes types ? https://ausmini.com/forums/viewtopic.php?f=2&t=482 |
Author: | ronniemac [ Sun May 02, 2004 4:21 pm ] |
Post subject: | Drum Brakes types ? |
I have two versions of wide drum brakes. One has the 1" spacer in a solid piece and the other type has 8 sections cut out between the stud holes as if to lighten it, part number 21A1279. Anyone know the difference ? |
Author: | drmini in aust [ Sun May 02, 2004 4:35 pm ] |
The 2nd type is Cooper S rear, the 1st type is Mini S (Clubbie). Both do the same job- my Mini has 1 of each at the mo. ps. there's another one too- only 19mm spacer bit- used on some Mokes... ![]() |
Author: | ausminis4u [ Sun May 02, 2004 6:43 pm ] |
another interesting fact is that the front shoes are WIDER than the rears, so i did a little playing round and the wider front shoes fit into the rear drums ![]() |
Author: | drmini in aust [ Sun May 02, 2004 7:39 pm ] |
NO! ![]() ![]() I've seen this tried a few times. Unless you pack the wheel cylinders out somehow the shoes won't sit square, and they will wear crooked. Anyhow, you don't need more braking on the back- on a damp road it's dangerous if they lock up. Concentrate on getting your Honda discs working... ![]() |
