Benefits of a Pertronix..
1. No more points to adjust or replace.
2. Timing stays set for long periods (mine is still right after 12 months).
3. Fatter spark- you can run up to .035" plug gap with stock coil.
4. Wear in the dizzy bearings won't hardly affect the timing as there's no points.
5. No points bounce. My motor used to get rough and lose power over 7000, now it's smooth to 8000+!
6. As long as the coil stays dry, no more wet weather ignition problems. I can hose mine now..
(I moved the coil onto the inner wing)
<edit> where do ya get it???
You can buy here and get ripped off, buy off MiniSpares and get ripped off less, or buy here-
http://www.vintageperformance.com/retro ... /lucas.htm
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
