Steel Flywheel Update. https://ausmini.com/forums/viewtopic.php?f=2&t=47042 |
Author: | Slo998 [ Mon Oct 27, 2008 7:57 pm ] |
Post subject: | Steel Flywheel Update. |
I have been reading throw the search results on here and there doesn't seem to be a clean answer. ![]() So what are the current 'good' ones to get? Are the new ultralight ones any good? It will most likely go in a 1293 with a Eaton supercharger, for manly track work. ![]() Thanx Nathan |
Author: | justfanginaround [ Sat Nov 01, 2008 9:48 pm ] |
we use the ulf and light backing ring and it does make a diiference the only problem so far was one of the welds split so we welded it again and added 3 new welds |
Author: | slide [ Sun Nov 02, 2008 12:17 pm ] |
Have a read of Des Hammill's chapter on flywheels in his revamped book on tuning 1275 A series. There's some interesting info on the pros and cons of steel versus cast fywheels. |
Author: | Slo998 [ Fri Jan 30, 2009 2:52 pm ] |
Ok well it’s been some time but I finally order a steal flywheel assembly. Ended up with getting one from MED engineering in England very nice to deal with and took less than a week to get here and no import duty ![]() According to the bathroom scales: MED flywheel: 3.9kg MED back plate: 1.4kg MED clutch package: 6.9kg STD one peace flywheel: 7.3kg STD cooper S backing plate: 2.3kg STD clutch package: 10.9kg So the MED item is about 4kg lighter then STD item, should make the new motor a bit livelier ![]() M E D ultra light steel flywheel ![]() M E D ultra light steel back plate ![]() AP Bonded clutch plate ![]() Gray Dot ![]() Thanks Nathan. |
Author: | graham in aus [ Fri Jan 30, 2009 8:57 pm ] |
Good choice for a road car ![]() I have run that set up, just great! ![]() |
Author: | gafmo [ Fri Jan 30, 2009 9:04 pm ] |
Reading your post, love to be where you are at the Moment ![]() Please also install a Crutch/ Clutch, Flywheel Sheild to protect Youself also Recently at the NB racing at Eastern Creek a fly wheel shattered ![]() Box was shattered but the sheild did its job...Pic's some where on here ![]() |
Author: | Slo998 [ Fri Jan 30, 2009 9:43 pm ] |
Yes the Flywheel Shield is going to be on the list of addition for this build I think. When I get all my stuff back from getting machined next week I will post up the new build the flywheel is going in to. Quick hint it’s a fully worked 998: 100” over, wedged, bladed and nitrated crank, lightened rods, centre main strap, the big 12940 head with it converted to 11 stud, new blower with 15 ish psi of boost and a few more goody’s. So I think it will rev well. ![]() Nathan |
