It is currently Mon Jun 23, 2025 11:49 am
 Post subject: Prices! thanks guys
PostPosted: Fri Apr 30, 2004 5:54 pm
hey guys!!
now just a few prices needed, if you have them at the end of your tongue, fill us in! thanks!
(ill add the prices in as we go on)
1275 gasket kit
1275 copper head gasket $33.89
metro turbo carb
flares (full set, the sort i have on my gt)
GT badge
radiator
mains and bigend bearings.. $44.88 $48.00
oh yeah, and do 1275's have different distributors to say a 1100? if so how much would one be?
that should be it for now, thanks!!
Last edited by -=MiniMafia=- on Fri Apr 30, 2004 6:42 pm, edited 2 times in total.
 Post subject: prices???
PostPosted: Fri Apr 30, 2004 5:57 pm
my radiator cost me $400....custom alloy item from link automotive...have phot if required..
PostPosted: Fri Apr 30, 2004 6:07 pm
as per karkraft catalogue:
Copper Head Gasket: $33.89
I couldnt find a full 1275 gasket set.....
but
Block Gasket set: 30.60
VRS kit with copper head gasket....all the gear for your head usually minus valve stem seals: 65.92
Normal VRS: 31.32
[Maverick] 1971 Mini K
PostPosted: Fri Apr 30, 2004 6:10 pm
thanks guys, this really helps :D
pics would be great thanks minifreak!
PostPosted: Fri Apr 30, 2004 7:26 pm
The copper AF460 gaskets are not the best any more- they tend to leak water at the front and the ends.
I only use them if people insist, and then I smear Loctite 515 Master Gasket around the outer edge.
Better by far for a 1275 or bigger is the BK450 black so-called `Turbo' gasket. It's cheaper too. :wink:
PostPosted: Fri Apr 30, 2004 8:42 pm
850pvan tells me that his flares cost $70 from link in melbourne
...its leaking oil... and thats a good sign!
It lets me know that I havent run out yet. :P -Tzi 4-9-04
PostPosted: Fri Apr 30, 2004 9:18 pm
Clubman standard flairs - $33 ea
PostPosted: Fri Apr 30, 2004 9:20 pm
Back in the 70's I was paying $19.99 for flares. Avco denim they were...... :lol:
Flairs on the otherhand, as above! :wink:
PostPosted: Fri Apr 30, 2004 9:22 pm
that $70 for 4 btw
PostPosted: Fri Apr 30, 2004 9:39 pm
4 pairs of flared jeans for $70....not bad! :lol:
Coincidently the Mini innocenti type flairs are about that price (ugly as sin IMHO)
Standard clubman or round nose flairs are $33 each. Usually $40 each though. Thats the original plastic flairs that crack when you look at them! :lol:
PostPosted: Fri Apr 30, 2004 10:41 pm
[quote="minitec"]Coincidently the Mini innocenti type flairs are about that price (ugly as sin IMHO)
I resemble that remark! :lol:
They are cheap, easy to fit, are the right colour (black) to go with my car (red), and are just legal with normal Mini Contessas. 8)
If I bust one they are all available separately.
One problem- the dumbnuts supply them with MS self tappers that rust the night you fit them. I fling 'em and use S/S ones from my friendly Bias Boating Warehouse..
PostPosted: Fri Apr 30, 2004 10:55 pm
Yea I read before that you have them and like them...I was waiting for your reply.
No offence, I think you stated before that they are cheap and do the job. fair call....
personally I prefer originallity over anything else, hence my preference for original flairs, and flares too.... :lol:
PostPosted: Sat May 01, 2004 2:30 am
i dont live in melbourne and my flares came with my pano :wink:
i think u meant 850_Van 8)
PostPosted: Sat May 01, 2004 4:28 am
Seriously its all getting much weirder.
850pvan got his jeans with the van (lucky they were the right size), the Dr "resembles"
a remark (the two probably have the same eyes) and Minitec (aka ....) despises the innocenti which was getting in terms of good design and usability where the brits never managed to.
PostPosted: Sat May 01, 2004 7:28 am
I had to put something on the `Matic to cover the 10x5 Contessas- and welding sheet metal in for the (now no longer made) MK2 flairs didn't seem kosher... :wink:
Only other problem with the Inno ones- the black plastic strip shrinks and gets shorter. I flung them and fitted some black pinchweld... it doesn't need to be glued on, either!
