It is currently Wed Jul 09, 2025 2:09 pm
PostPosted: Thu Aug 29, 2019 10:29 pm
Hi all,
I have a 64 850, the boot lid has been replaced at some point in it's 55yrs with a boot lid from a 1965 Deluxe.
Will the original 850 badging fit in the deluxe badging holes? If not, can some one please post a pic of the original boot lid from a 1964 850..
From my understanding the 64 had the Australian spec number plate flap rather than the English version..
Thanks in advance
1964 MORRIS 850 - POST ZOMBIE APOCALYPSE CAFE RACER INSPIRED.
https://spotify.link/D0P4KtIP2yb
1098 +0.40
266 Kent Cam
GR Flat top pistons
HS6
1.3:1 Roller tip rockers
Stupid high CR
PostPosted: Fri Aug 30, 2019 10:51 am
are you sure that it was replaced? I'm the second owner of an original 64 and it has the small number plate flap.
The deluxe has Morris Mini Deluxe badging. The holes do not line up with Morris 850
PostPosted: Fri Aug 30, 2019 11:08 am
The change from the wide UK style to the narrow Aussie style happened during 1964, so depending on the date of the car it could have either (change around car 51000)
PostPosted: Fri Aug 30, 2019 1:42 pm
If it helps, here is the tech drawing for the Aussie Boot Badge holes for the Morris 850 - courtesy of Winabbey.
PostPosted: Fri Aug 30, 2019 8:25 pm
Thanks mate, mine 57xxx.. it's good to know that mine had Aussie boot and doors rather than English.. (altho I love the sliding windows and long number plate)
Sent from my SM-G960F using Tapatalk
1098 +0.40
266 Kent Cam
GR Flat top pistons
HS6
Stupid high CR
PostPosted: Fri Aug 30, 2019 8:27 pm
Thanks mate... saved for future reference.. [SMILING FACE WITH OPEN MOUTH]
1098 +0.40
266 Kent Cam
GR Flat top pistons
HS6
Stupid high CR
PostPosted: Fri Aug 30, 2019 9:37 pm
I put my badge on with good quality double sided tape. Hasn’t looked like falling off and no holes required.
Why don't people believe me when I say Arianca Tan will make a come back.
