SERIOUS HELP WANTED... https://ausmini.com/forums/viewtopic.php?f=2&t=355 |
Page 1 of 2 |
Author: | IwannaMini [ Sat Apr 17, 2004 10:55 pm ] |
Post subject: | SERIOUS HELP WANTED... |
Guys, I was wondering if anyone can help me...? I have found this wicked little mini (it will be my first) and I wanted to make sure that I know what I am getting...!!! I have the following details: Serial no - 5926 engine no - 9ye/u/H-2813S type - YJEAV2R Its a little round nose panel van but the guy selling it has no idea about the details what so ever. How do I know what engine this has or is meant to have..? I think that its a 68 or 69. Which of these details do I use for a REVS check..? Any help you can give me is MUCH appreciated..!! Also there are a few bits and pieces missing like the window washers, radiator cap and air filter. Does anyone have any of these parts lying around that they dont want any more..?? ![]() |
Author: | ClubmanGT [ Sun Apr 18, 2004 6:22 am ] |
Could the body type code be YJBAV2 (note 'B' not '3')? If so, it is Morris Mini van, Aus model. with 998cc motor code 9YE/U/H. Looks like original motor with van! Have a look at the following: http://www.bretts.com.au/~con/mini/engnrtmp.html Cheers Gavin |
Author: | min13k [ Sun Apr 18, 2004 10:16 am ] |
rad cap buy brand new the air filter i have a few of the originals here if you want me to look at the car for you i will just to help you so we can see what work you need to do makka |
Author: | ausminis4u [ Sun Apr 18, 2004 5:55 pm ] |
Post subject: | Re: SERIOUS HELP WANTED... |
IwannaMini wrote: Guys, heres a list of info i posted on the old ausmini http://www.atmodigitaldesign.com/ausminiforums/viewtopic.php?t=218&highlight=morris&sid=28269cbecff30ce51d72779a16895cfa
Author: | IwannaMini [ Sun Apr 18, 2004 8:40 pm ] |
THanks for the help so far..!!! ![]() ![]() ![]() |
Author: | poeee [ Sun Apr 18, 2004 11:06 pm ] |
I'm unsure when they first started doing this, but all Mini's I own have the month and year of manufacturer stamped the plate. Though I have nothing pre Jan 1970. |
Author: | dr trim [ Mon Apr 19, 2004 1:16 am ] |
mine has it stamped 66/8 in my morris mini panel van, so im pretty sure that one would have it unless it's dodgy ![]() just look under the bonnet on the driver's side where the frame of the car molds for the headlight at the front. if that makes sense ![]() |
Author: | min13k [ Mon Apr 19, 2004 5:51 am ] |
have a look at the windscreen wiper motor it has the aroundabout date on there makka |
Author: | clubmn [ Mon Apr 19, 2004 6:44 pm ] |
Post subject: | NA |
The windscreen wiper motor isnt the best place to look at a manafacture date.... If you didnt realise mini13k that is another LUCUS part...... How many people have there origional wiper motor on there car... I changed mine twice... FU-K lucus.... |
Author: | ausminis4u [ Mon Apr 19, 2004 6:52 pm ] |
Post subject: | Re: NA |
clubmn wrote: The windscreen wiper motor isnt the best place to look at a manafacture date.... lol good call clubmn If you didnt realise mini13k that is another LUCUS part...... How many people have there origional wiper motor on there car... I changed mine twice... FU-K lucus.... ![]() |
Author: | drmini in aust [ Mon Apr 19, 2004 7:09 pm ] |
Only the last of MK2s had the proper ADR plate with the date on it. Up to around 1968 the plate on the firewall showed chassis no, engine no, and colour, but no date.. Many 1969 cars had SFA, except the number stamped into the radiator shroud. So if it's a `69er, and a van, only the wiper motor has a date. (but cars had a date on the boot lock too). I have been told the MiniCar Club of NSW have a register of what was made when, based on engine number. Sorry I don't have the list, and I dunno if it covers vans.. I will ask the question and report back.. ![]() <EDIT> The fact you obviously have a chassis plate on the firewall (to get the number and type) means it's probably 68 or earlier, IMO.. <EDIT 2> which side do the wipers park, and are the wiper shaft shrouds recessed into the panel? |
Author: | drmini in aust [ Mon Apr 19, 2004 7:44 pm ] |
Hey clubmn... I got 3 Minis- `64, `70, `78... guess what, they ALL still run original wiper motors.. that work! ![]() |
Author: | Mike [ Tue Apr 20, 2004 3:50 am ] |
Mine is an original motor too (1970) and it worked fine up until a week ago. Anyway if its a 68 car the motor would be 36 years old - its 36 years of service and exposure to heat, dust, vibration etc by a mechanical device with multiple moving parts with minimal servicing and lubrication (if any at all). Thats pretty impressive people, unless you live in lala land. And if 36 years of service doesnt satisfy you that means you automaticaly disqualify from owning any modern car where stuff starts breaking much sooner (and there's much more stuff to break). |
Author: | drmini in aust [ Tue Apr 20, 2004 6:47 am ] |
OK here's the reply from my friend Graham in Aust (on MS board)... "Kev, Info I have shows YJBAV2R as Morris Mini Van (YJEAV2R I would suggest E should be a B) this could have been an Early 998 Mini van, possibly flat roof? Sliding windows? Changeover to winders was probably 65 as per deluxe? I suspect that all sliders were 850’s, and probably 998 and winders came in together, not sure about roof though? Does it still have sides, or windows fitted? Anyway, 9YEUH is correct motor code, number would obviously depend on age, I would guess (not in my list) late 67 early 68? With winding windows, what date is on wiper motor? / switches etc. What style trim and colours? There were some commercial grade trims out around then, different to all other Mini’s, I have a blue 66 Van with blue commercial trim, not got the numbers to hand at present, but here’s a pic! If this new guy does not want any of the original trim, I might trade him for later stuff? Cheers Graham" <EDIT> email me for the pic- I can't host `em- I got 50MB of space on Swiftel and dunno how to set it up.. ![]() Kevin ![]() |
Author: | bobtel [ Tue Apr 20, 2004 4:12 pm ] |
Mine has the original wiper motor too. But it only gets turned on once a year for the rego check. I cut too much rust out of the thing when I restored it to drive it in the rain. Bob |
