It is currently Fri Jul 25, 2025 9:27 am
 Post subject: Attaching chrome strip
PostPosted: Tue Jul 10, 2007 8:58 pm
Rover Cooper
Gentlemen, is there a secret to attaching the chrome strip down the side of the car with wide flares fitted. My car has just arrived and I need to re do it because it has crimped on the bends and looks rather chatty.
I think its chrome plated palstic strip, any ideas.
David
PostPosted: Tue Jul 10, 2007 9:07 pm
Some threads before discuss this horrible job. Time consuming, frustrating.
Last time I did it I used a heat gun to soften the trim so that it bent easier round the corners, but you have to be careful not to soften it too much. Plenty of wailing & gnashing of teeth :evil:
PostPosted: Tue Jul 10, 2007 9:16 pm
I used a hair dryer. A heat gun may burn it. Be careful
PostPosted: Tue Jul 10, 2007 9:29 pm
oh yeah, certainly is easy to damage with a heat gun, I'm a culprit of that.
I laid them out in the sun (in melbourne? pah!) held down by weights for a week to get rid of the tendancy to curl up on themselves. It all helps.
....or let the curl work in your favour, force it to bend the other way for the arch, but use the tight curling tendancy to negotiate the tight corner at the back of the front arch and front of the rear arch. Flip the roll over so that it faces the right way. If you are not careful, the buckling will pop up in a second on the new trim as well.
PostPosted: Tue Jul 10, 2007 9:30 pm
There already...
it only left yesterday
Miniworx Centre 0883741299
Online BMW Mini Shop
PostPosted: Tue Jul 10, 2007 10:02 pm
Forum Graffiti
Is it the straight stuff or the fluted good stuff?
I wouldnt even bother with the straight anymore as I could never get it to stay there and it bent funny... :evil:
The fluted stuff is much better and it stayed on for me without glue :D
 Post subject: Chrome Strip
PostPosted: Wed Jul 11, 2007 6:25 am
I just finished fitting mine i used a hair dryer and lots of patience.
Steve
Classic Not Plastic
PostPosted: Wed Jul 11, 2007 8:33 am
Give Ash some flowers Nick .
Same here - hair dryer and lots of patience. Really hot water can work also - have a big bucket near you - dunk it in and warm it up then work really fast!
PostPosted: Wed Jul 11, 2007 9:13 am
Look at the way it's wound into a coil as well and then the cirves on the mini arches , you want to bend the strip backwards over the big curve around the wheel arches so the small curves in front of the rear arch and behind the front arch take the strip still bent in the direction of the coil .
PostPosted: Wed Jul 11, 2007 2:38 pm
we ran it through a bucket of hot water and used glue and clamps with wide heads and material to stop it pressure one point
Enjoy Chris ;)
PostPosted: Wed Jul 11, 2007 6:05 pm
Years ago I discovered that there were two brands of the Cooper S type plastic strip. One was quite easy to fit and the other would never like to unroll even after soaking in hot water.
PostPosted: Wed Jul 11, 2007 8:58 pm
The part of the strip that goes from the body to the arches is starting to come away on my S. I'm so tempted to buy some new trimming and do the job, but everyone tells me nightmare stories :(
PostPosted: Wed Jul 11, 2007 10:04 pm
Nah it's not a nightmare, just put aside a couple of hors to do both sides. It looks like an easy job, so people rush it.
Just know that you will be there for a while to get a superb job.
PostPosted: Tue Nov 29, 2016 8:03 pm
How about using one of those steam mop cleaner thingos. The one they use to clean bathrooms etc, not the actual mop one.
PostPosted: Tue Nov 29, 2016 8:10 pm
That sounds like a great idea
1968 Morris Mini Cooper S
